3.25 lbs Lithium Ion Battery, 725 Amps!
Can they really deliver 720CCA? that's pretty impressive.
Consider PC680 was the go to drycell for many years and it is 15lb with less advertised cranking amp rating.
You try it!
Jim
Jim
http://www.batterytender.com/Batteries/
Reading more on them some of the motorcycle guys say they have to wake them up before they will deliver full cranking amps. Several guys said they would turn the key on and let the light draw for a few seconds before attempting to start the bike.
BUT the charging instructions say not to put more than 10 amps charge current to them so you have to wonder how they withstand the alternator current at constant running.
I don't want to be the first to have one blow up under my seat that's for sure.
FWIW the "Shorai" 36 Ah LiFePO4 battery has been available for years now around $275 at ~5 lbs and according to many reviews is just fine being charged by a regular car alternator. This battery is probably fine too.
+1 on the Shorai. I've been running one in my 96 for the last year. I keep it connected to a BatteryTender when it's parked. I've run it down a couple of times doing stupid stuff like leaving the console open and it recharged with no issue. It has enough juice to crank the car for a while. It does seem to be affected by cold. Things get a little draggy when the temp is in 30s.
I've been running a Shorai for the last two years during the summer without issue. I agree they do lose some power in cold weather. I pull mine out over the winter and maintain it with a standard Battery tender. Great batteries IMO.
On the cheaper side I have been using these 11 lb lawn tractor batteries for a few years. Have one on my gate opener, one in my 99 Mustang GT, and one in my John Deere 855 Diesel tractor. They only cost $25 at walmart with exchange.
This one has been going strong for 4 years and I even have AC and a radio in the car. I used an aluminum heat sink off one of the old stereo amps for a spacer and replaced the cable ends with crimped and soldered eyelets.
I have the same battery in my 3cyl diesel John Deere tractor and even though it sits for months it still starts without having to be jumped off.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've been using the slightly bigger brother of that battery (360CA/300CCA, 16#, $29 at local Farm store) in my '69 for the last 4 years. Starts the car just fine at 40* temps (haven't tried at any lower temps). Recently put the same size battery in my C4 (although with a cutoff switch due to ECM/radio current drain during storage).
When the garden tractor needs a new battery I might get a smaller size and try it in the Corvette first.
Last edited by 69427; 02-03-2015 at 12:35 PM. Reason: Corrected (reduced) battery weight.
Lithium ion batteries can catch fire while being series charged like they are in a car, and they burn a lot like magnesium. That gives me the *******.
LiFePO4 batteries are a different chemistry, and won't burn like a lithium ion battery. I think the Ballistic LiFe is a much better battery.
The one in the first post (and every other that I've seen) is lithium iron phosphate just like ballistic and shorai.
A lot of people seem to confuse "Lithium Iron" with "Lithium Ion" - that "r" in there changes the meaning significantly as you noted.
