How to set caster - video
St. Jude Donor '15
you say 20* and only turn the wheel a half. in my camber change in turns thread, i posted an update yesterday. to get 20* i had to turn the wheel in the c6 z06 almost 7/8 of a turn. using that as a baseline, then at half a turn you are only getting to 10*.
I think Froggy is right at 10deg based on 2.62 multiplier. It comes from below formula
Caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
sourced from http://quadesl.com/miata_alignment.html
by this math though the multipler is slightly off using 16.1 steering ratio
1/2 turn would be 2.56
Nice vid, I need a camber tool... I use straight edge and level which is a little tedious.
Correct, I just set toe now & left the key in, just kept going back to check it centered each time I adjusted. Actually I thought the toe would have changed more with the .2 deg neg I took away but It did not change much 2 to 4/32nds.
Received 8,928 Likes
I looked at that tool and then purchased this:FASTRAX CAMB/CAS GAUGE 91010. It works well but uses a bubble gauge which I was having a hard time reading the gauge due to not enough contrast (it is PIA to get old). I replaced it with the Longacre Digital Caster/Camber gauge witht AccuLevel. It is really easy to use. It magnetically attaches to the hub and there is a large enough hole in the center it will fit over the end of the rear axle shaft. Just pop off the hub cap, turn on the level and let it zero then pop it on the hub, adjust the sideways tilt using a small bubble level on top of the unit and read the camber on the read out. The digital level unit can be removed from the magnetic holder and used to measure angles like the C7 Corvette requires when setting rear caster.
http://www.longacreracing.com/produc...Level%E2%84%A2
If anybody wants to make an offer plus shipping for the Fatrax unit with the no lip adapters it is available. It has only been used three times and if you have young eyes should do a good job. If you want to look up info on the tool here is a link: http://www.spcalignment.com/componen...tion&pid=91010
Bill
Bill
St. Jude Donor '15
when measuring caster using my hunter alignment machine, i only turn 10* left/right. when i tried the formula with the numbers i got doing 20*, it did not come close.
https://www.corvetteforum.com/forums...-in-turns.html
St. Jude Donor '15
Using the steering wheel if 1/2 turn = 180*/16.1 = multiplier 2.56.
I tried your thread alignment readings and was almost dead on +\-0.1*
St. Jude Donor '15
c6 z06 20* readings
2.16 - (-2.98)= 5.14 * 2.62 = 13.49
now using the 10* turns from the wrx
0.69- (-1.98)= 2.67 * 2.62 = 6.99 then it's correct.
St. Jude Donor '15
you can se eit here from the c6 z06 i checked
St. Jude Donor '15
something to consider when taking measurements. may want to take into account you being in car.
https://www.corvetteforum.com/forums...post1588906001
Yes I agree.
