Sparco Evo L in a C5??
Wondering if anyone had success in fitting an Evo L (the mid size version) in a C5? I know these cars will only accomodate certain seats, and Saferacer informed me they would not take it back if I determined it would not work. From reading other posts, I believe the small version fits, the large version does not, but I don't know if you can fit the medium. Thanks for your help!
It is TIGHT between the thigh bolster and the tunnel but they go in there. I just put the new seat cover with the white piping on the driver's seat and had to unbolt it in order to get the old cover's cable out from between the tunnel and bolster. These are Evo2's.
Former Vendor
I put a pair in my C4 Auto-X car. They needed trimming on both sides at the front bottom corners. I pulled the cover back into place (making sure to smooth the fiberglass not to tear the cover) when done and could not tell it was not stock, mine had a small spring that attached to the material pulling the cover tight.
Hope that helps
Best regards,
Ralph
888-308-6007
Sales@jdpmotorsports.com
Hope that helps
Best regards,
Ralph
888-308-6007
