C5 Z06 on the Scales. Why you shouldn't adjust ride heights without scales.... PICS
When I got the car, the left front bolt was almost full down, right front 4 turns up. Rears were opposite, but the ride height measure from the the jacking pucks was within 1mm front and 2mm rear. With about a half inch of rake. Fender gaps were all about the same too.......BUT
Found a shop that would loan me scales for 40$.
Full of fuel, only mods a Momo steering wheel, and borla exhaust.
Zeroing all the bolts got it pretty close, 2-3 adjustments later.....
Seriously do you guys think this is close enough? I also got the car aligned, camber and toe were way off side to side.
After all this the car changes direction like a cracked out spider monkey. Its almost too responsive, and a little nervous feeling. Could be the 0 toe.
Gained 200 lbs from 1st shot to second shot.
So you sat in the car then?
So then it's not an apples to apples comparison.
If you had the same Weight in both shots, i.e., you sat in the car in the drivers seat both times, then it would be a better comparison.
Sitting in the car dramatically affects the loading on the tires.
Supporting Vendor
I'd corner with a full tank... because that's how I run my car.
Looks good "after". How different are the bolts now, just curious. My car is going back on scales next week (it's too cold to work in my shop right now). I'll be curious how yours compare.
FYI:
Corner weight with 1/2 of predicted fuel load and driver weight properly distributed in car wearing all gear. Fill any cool suit tank too as raced. Tires with hot air pressures as raced.
How close do you shoot for Sam? I figured less than 1% cross weight was good enough for a daily driven car that see's 2-3 track days a year.
While I was at it, I weighed my Formula with your Springs, Bars, and koni shocks. Needless to say I was pleasantly shocked with how close the corner weights were. Car is full of fuel, no driver, and about 50lbs of sound deadener in the back.
Thanks for making a great product.
For a street/DE/autox car, I like to get within a tenth or 2 on cross with 1% variance being more like the initial starting point.
BTW, are you using slip plates or ramps when you get the car onto the scales?
Sidebar: curious about this ^^^. Mind sharing the reasoning? Is it a matter of reducing slosh/weight migration, front to rear weight split, or does the extra weight in the rear aid with rotation or putting down power? Thanks!
Corner weight is very important! Ride height, not so much!
Jim
Jim
Why is ride height not important? Too low and you're into the bumpstops, too high and you've raised the CG as well as missing out on some of the camber curve. That's without even look at the impact of rake on handling.
Or do you mean that ride height "for looks" isn't important?
The less front to rear rake you have, the tighter the car should drive (based on feedback from folks with way more seat time in these cars than me). My personal experience in other platforms has mirrored this though the Corvette may be more sensitive to rake than other cars that I've had.
IMO, all Corvette's look kinda like they've got a 4x4 ride height with the notable exception of some dedicated track cars and others that are at an impossibly low ride height. You can't get away with that sort of setup on a street car without being all over the bumpstops and scraping on everything (assuming stock spring rates & stock length dampers).
I don't know... I just like fiddling... I also have very little total seat time and this is only car I have competitive driving experience in, so mostly I just drive it for a while until someone else drives it and says something is wrong. It does look a bit silly though, haven't taken real measurements. I'll just leave it alone for now...
FWIW, I think the ride height on mine "looks" higher than most cars that I've owned but it's (apparently) in the right place. I've got relatively little seat time in mine thus far but prior experience in club racing/autox.
Jim
Supporting Vendor
However, I know the 'internet' says I'm nuts for it. So, well I'm nuts.
I've full, dead empty, in the middle, etc. I tend to.... oh, do "ok" speed wise and I'm already the biggest heaviest guy in the class. Add fuel and the car is that much heavier, doesn't seem to hurt me much. If was faster with less fuel I'd do it. I'm not.
Cornering with 1/2 the predicted fuel load, why? With driver makes sense, you don't corner with 1/2 the driver's weight in the car do you?
__________________
Sam Strano
Strano Performance Parts
www.stranoparts.com
814-849-3450
More options than any other single company out there. More parts than any other single company I know: Brakes to Safety, Wheels to Exhaust. Suspension to Air Filters: Girodisc, Hawk, Raybestos, Essex Racing/AP, Ferodo, Wilwood, Penske, Koni, Borg Motorsport, Ridetech, Viking, After Dark Speed, Hotchkis, Bilstein, KW, Forgestar, BC Forged, Forgeline, MRR Wheels and on, and on, and on it goes.
Sam Strano
www.stranoparts.com
814-849-3450
Because they car is faster and IMHO easier to drive with a full tank of fuel. And yes power down is no small part of that.
Location: If you don't weigh in you don't wrestle Road America
When I set a car up for NASA races I like to set it up with around 1/2 tank so that the balance doesn't change too much through out the race. From dead empty to full I see around 1/4" difference in ride height, if I set up with 1/2 tank I'm only changing 1/8" lower at the start of the race to 1/8" higher by the end.
The way I see it the cars only going to full for the first 1/4 of the race - and you aren't going to be empty for very long. If I set it up with 1/2 tank I should be in the sweet spot longer.
If I were setting the car up just for TT it would be a different story, plus we always have to worry about those pesky scales after races and TT sessions.
