Suspension dilemma
Suspension dilemma
Later this summer or early fall I will be getting new shocks, but I cannot decide if I want to go to coil overs or just go with a set of the Koni yellows. I know the Konis are far and away cheaper, but at the same time I would like the adjustability of the coil overs. What are the benefits of a coil over setup vice just doing the shocks, and what are some of the other things I would need to do if I went to a coil over setup?
Kerry
Kerry
Kerry
Kerry
im just trying to determine what length shock to get. I have found some QA1 coil overs with 400 lb spring for $450 free shipping.
Coilovers allow easy height adjustability plus reasonably easy spring rate swaps. If you add aero later you can order new springs and step up the rates to match your new downforce. The car will not have the cross-talk that the transverse leaf springs cause. The car will feel more settled over curbing and rumble strips. All of this assumes you have correct spring rates for the shock valving and you have them adjusted correctly.
Coilovers to fine tune spring rates/ride heights.
Kepp in mind adjustment method on shocks. Koni yellow with the 1/4 window sweep gets annoying and not user friendly.
I suggest looking at Viking coilovers for cost effective option. Triple adjustable and very easy to adjust via external *****.
I can't help you w/ specifics but will make a recommendation based on my previous car. Go to double adjustable if you can any way swing the $. In addition to tuning handling it is really nice to have a setting for street and another for race/AX. I'd much rather have DA shocks only than SA coil overs.
Smitty I see a huge empty place in the Viking application chart for 2014-2019 Corvette.
TexasDanny (05-22-2021)
