Pfadt Gen 1 SA coilovers
I purchased a car that has the 1st Gen Pfadt coilovers on it.
Can anyone tell me what is being adjusted in the 1st Gen coilovers when you select one of the 18 clicks?
Is it rebound only, compression only or a combination or rebound and compression?
Asked the same question and rebound was the answer I got. They blew a few months after I got the car, however. Went to the DRM Bilsteins and they were a massive upgrade, fwiw.
Did u have the coil overs? If so, I assume u went back to the leafs with the DRM's or do they have a version with a threaded shock body that will accept the coil portion of the pfadts??
