HPDE: Carbotech XP10s with OEM GS rear pads
Old 05-14-2015, 06:18 PM
GS-FLA
GS-FLA's Avatar
Default HPDE: Carbotech XP10s with OEM GS rear pads
Hey guys,
I am going to be taking my GS to the track for the first time on sunday. I will be flushing the brake fluid with Motul 660 (got 1.5 L for it).
I had some miiiinor brake squeak earlier this week, so I decided order Carbotech XP10fronts/8 rears. I ran Carbotechs on my last car at the track and like them.
The problem is, I couldn't find the 8s anywhere so I ordered the 10s anyways. I haven't had the chance to see if my current pads are dying, but when I do so on saturday, and decided there is not enough for a full day, would it matter if I run the XP10s up front, and the oem rears out back? Too much brake bias?
Ps. I didn't want to go to Xp12/10s because I am on street tires, so no need. My plan is to run the Carbotech 1521s (street) during daily driving, as swapping carbotech for carbotech you won't have issues reusing the same rotors.
Thanks!
Old 05-15-2015, 07:39 AM
rocsvette
rocsvette's Avatar
Originally Posted by GS-FLA
Hey guys,
Thanks!
I've run XP/10 stock rear for years on my Z06, no brake issues at all.
Old 05-15-2015, 02:24 PM
Rob Willis
Rob Willis's Avatar
If you run with all "nannies" on you may wear out the rears much quicker then fronts. Other then that I'd say you will be fine.
Old 05-16-2015, 11:52 AM
Last C5
Last C5's Avatar
I did the same without any problems and now I run XP10s on all four corners without any problems.
Old 05-18-2015, 11:35 AM
GS-FLA
GS-FLA's Avatar
Thank you guys very much!
I ended up swapping the front pads to the XP10s, and they worked perfectly!
A few pics as retribution for your input
Old 05-18-2015, 11:58 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Happy to hear it worked out for you
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
To HPDE: Carbotech XP10s with OEM GS rear pads
Quick Reply: HPDE: Carbotech XP10s with OEM GS rear pads
