Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
#61
Premium Supporting Vendor
In China. We torture tested these lug nuts with over 100 torques at full impact way over the torque spec until the stock stud broke. We're very happy with the quality and feel comfortable putting our name on them.
#62
For what it's worth. I've been running these for a little over a year with probably a dozen wheel changes (track to street wheels). Using ARP on my SKF hubs and stock bolts on my stockers and haven't had a single issue with the lugs. Just make sure you re-torque them after a couple laps. Very happy with the product, also they are disturbingly light.
#64
Anyway I'm on my 5th year with these and there are zero issues. My only "complaint" if you want to call it that, is that it's hard to find impact rated 12 point sockets. If I can pass a tip on to Jason (we talked a couple of times) is to offer ONE 1/2 inch drive impact socket with a set of 20 nuts. Charge a little or even make it free. I think you'd be pleasantly surprised at the response (sales).
Don't forget if you do this send me a couple (they get lost), I'm still using non impact.
Froggy.
#65
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
I am the guy (when these originally came out) who asked how many seasons will they last. Well it was a dumb question for obvious reasons, a "season" for one guy is 4 events, for me it's closer to 40.
Froggy.
Froggy.
lol yah a seaon for me is the entirity of the NASA Texas region, a ton of member days and HPDE's.
My stupid impact socket for these nuts is ridiculous, hardware stores don't carry it. I forgot it one event and ran cycled out **** tires for the weekend because I couldn't change wheels. (to far to drive home and not enough time to order a new socket, local stores had none and nobody not retarded uses 12 point at the track.
#66
Hah, the socket issue is one of my big hangups too. I currently have splined nuts on my wheels and I want to get rid of them because I hate having a non-standard socket.
#67
I just use a non-impact on my Milwaukee electric impact. Worst case, i ruin the socket and replace it. Not difficult or expensive to keep a couple sockets on hand. Again, I've used it hundreds of times without issue.
#68
There ya go, HELLO KATECH, it's about the SOCKET.
#70
https://www.amazon.com/Sunex-267217-2-Inch-12-Point-Impact/dp/B006L238FA/ref=sr_1_6?ie=UTF8&qid=1549389893&sr=8-6&keywords=17mm+socket+1+2+drive
I've been using it for a long time now.
#72
I took them off and when i went to put them on they were just all jammed up and wouldnt thread down. Studs were fine and accepted other lug nuts. v0v
#74
im traveling for work so don't have them any but i kept them ill snap a pic when i get a chance.
#75
WIKI INFO below
It is significantly stronger than the most commonly used grades of steel. As others have noted, the strongest known alloy steels in their strongest tempers are stronger than the strongest titanium
alloys in their hardest temper. ... As others have pointed out, Titanium is remarkable for its strength, given its weight.
My experience with most cheap lugs is that they fail before the stud. I imagine the Vette studs are a "good" grade steel but probably not as good as ARP's. It woud be interesting if KATECH could chime in to provide the actual hardness number (such as 200,000 psi tensile strength) if they have it. It had to have been specified to the company that made the lugs that KATECH sells.
Here are some for ARP studs made for NASCAR
ARP Wheel Studs - heat-treated 8740 chrome moly, tensile strength of 200,000 psi, sold in 4 or 5 packs, cadmium plated for extra durability, nuts not included
NASCAR Speed Studs - heat-treated 200,000 psi chrome moly steel, precision J-form threads (formed after heat-treat for improved fatigue strength), nut-starter and bullet shape radius, shot-peened, baked-on dry film lubricant, and double magnaflux inspection, fits the registers of all popular hubs without grinding
NASCAR Speed Nuts - profiled nut face for easy installation, quicker socket releases and resistance to jamming, heat-treated chrome moly, nominally rated at 200,000 psi tensile strength, shot-peened, double magnafluxed, coated with Alumotef III
#76
Thank you.
WIKI INFO below
WIKI INFO below
We torture tested the lug nuts with 100+ impact torques well above the torque spec until the OEM stud failed. There was no structural damage to the lug or threads. The conical seat had some expected wear and tear due to the harsh impacting.
#77
The lugs are made from Grade 5 6AL-4V titanium which has a tensile strength of about 170,000psi.
