Does anyone have any braking questions.
bfit (01-30-2018)
#1602
Did a track day this past weekend and had a minor issue that maybe you guys can answer.
On my '03 Z06, the first hard braking during my session caused the car to get really squirly. Once the brakes were warm, I had a nice, solid pedal and the car was stable under braking.
My car has ABS of course.
I can think of a couple things that may have caused this, but what do you guys think?
#1603
#1605
Could be, but I don't think so. I bedded them in again on the road just before pulling into the track. Also, it didn't only happen in the first session.
#1606
Supporting Vendor
Same thing I always ask.
Tires?
Car mods?
Driver skill?
Event type and track?
Other?
#1607
It felt like the rear was locking, but it may have just been the front brakes darting.
I guess to figure this out in my own mind I have to ask:
1) What would the car do if you had unequal braking in the front; i.e. if the right front brake was working normally but the left front brake was barely working. This on an ABS-equipped car.
2) What would the car do if you had unequal rear brakes, such as the right rear brake working fine but the left rear brake not working. This on an ABS-equipped car.
#1608
How would you compare the streetable PAGID pad compounds vs the Ferodo DS2500? Are there any PAGID race compounds that are compatible with their streetable compounds so that one can use the same rotors?
#1610
Received 8,919 Likes
Did you adjust the shoes so they fit properly within the drum inside the rotor hat? There is an adjuster at the top that has to be turned to expand the shoes out to the drum surface. Auto parts stores sell gauges that measure inside diameter of drum and translate that to the outside diameter required for the brake shoes.
#1614
Supporting Vendor
They are well liked by many and the XR1 is the compound for race tires.
I list them for some OEM applications and I am getting to listing them for aftermarket calipers now also.
They are made to order in MI and Andie is a great guy to talk to.
They do have brass rivets in there so you may not want to run them all of the way down.
ST60
http://www.knsbrakes.com/c/caliper-s...328_Cobalt+XR1
ST40
ST60
ST40
#1615
Did you adjust the shoes so they fit properly within the drum inside the rotor hat? There is an adjuster at the top that has to be turned to expand the Pads out to the drum surface. Auto parts stores sell gauges that measure inside diameter of drum and translate that to the outside diameter required for the brake shoes.
#1616
Bill
#1617
5th Gear
Okay, Johnny C, I have a '08 base model with Z-51. I have 50k miles on it and the pads are starting to wear down pretty far. Can't say I'm in the danger zone yet, think I have a ways to go before that. I grew up in my dad's garage and I've always done most of my work mainly to save money. I've got some age on me now but I'm still considering doing this brake job myself. I'm even going to paint the calipers before re-installing. I guess I could go the cheap route and just put new o-rings in the calipers, slap some pads on there and go with it. The drilled rotors do have some wear but I'm not sure what the minimum thickness should be and whether I will reach such a point before I have to do brakes again, which will likely be never since I'm 70 years old. I do realize that the car is now 10 years old and maybe some other things should be considered. Hope I'm not putting you on the spot here since you feel like I do that safety comes first.
Actually, I've been a member since 2013, but I can't remember my login info so I had to start all over again with a new member account. Ain't bad memory a *itch.
#1618
If you're looking for pads, on a non tracked Z-51 car, I would look at GM replacements in ceramic. They'll dust less. I'd also check the wheel bearings since you have everything apart. Hope this helps
mike
#1619
Supporting Vendor
The minimum thickness should be 32mm (new are 32mm)
The Z51 pads are pretty good so if you like and use the stopping up in those mountains you might want to make sure you get a stronger rather than weaker compound.
Pads, maybe rotors, clean and grease the slide pins and you should be good to go.
#1620
Bill
