Does anyone have any braking questions.
#1781
Also, on a 2001 you can take off the electronic half of the module without opening the lines, it's super easy and saves some mess/hassle. My buddy just did it on his car and it worked great, no air in the lines or module to fight with.
#1782
However, considering I fought with the exact same problems Latebreak mentioned, I wanted to be sure it was purged just to be confident no air had worked itself into the system. I have no way of knowing if all of the issues were the failing output solenoid or a combination of solenoid and air. Maybe the failing solenoid let air into it. Not a clue. I'd just rather not find out at the first track day.
Thanks guys! I'll look at the Tech2 or Mongoose substitute, as it could be helpful with both of my C5Z's. What else could I do with it to justify the purchase? Short of that, I'll take it to the dealer. I just prefer they do as little work on the car as possible.
#1783
I think it was mainly because I had bought the module a while back, so it had been sitting on the shelf for about 2 years, so there was a lot of time for fluid to seep out of the ports and internal passages, and for any remaining fluid to pick up moisture from the air. In any case, it made for a stressful year of racing.
#1784
This is what I read on ABSFIXER, that simply removing the module wouldn't introduce air into the system. Absolutely no fluid dripped out when I removed it...so I assumed that was a true statement from them.
#1785
I check for codes after every event. It will tell you lots. I also check for overrevs etc.I'm using the GDS2 software. So far I haven't had one. It's how I knew I had a misfire on cyl 7 and 8. You can also sign up for a 2 year subscription for Vehicle programming updates but probably not too usefull unless there are updates you want and don't have.
I'm leaning toward taking it to the dealer, since I don't know if I'll ever use any other function on the device. But that's also ignorance talking, since I don't know enough about it.
#1786
I have a brake question, how can I keep my ABS from going berserk when autocrossing. ABS messes with me way too much. I much rather my 95 Camaro brakes lol.
Mostly a rhetorical question...I know this is a common issue. Its something I need to dig into more. Super annoying having ABS and or ice mode interfere.
#1787
#1788
It looks like the GM Tech2 is only $252? What does the MongoosePro give me that the Tech2 doesn't for twice the cost? Most of the codes will show up on the DIC or my basic OBDII scanner. You can't check for over-revs, but it told me what the ABS problem was.
#1789
I was just researching that a bit and came to the same conclusion, they are all Chinese. There were posts on this forum of people that didn't have such great luck. I think I'll go for the Mongoose if I do anything, but will likely have the dealer purge the system for now.
#1790
#1791
Received 8,928 Likes
I have a 2001 ZO6 with APRacing Radi-CAL front brakes with Ferodo DS1.11. OEM rear hardware wish Ferodo DS.11 also. Last year, I fought with an intermittent ABS module until it eventually failed completely (left rear output sol was intermittent, and eventually stopped working). Wanting to avoid downtime (and not knowing at the time I could run without it), I just went ahead and finished the HPDE season with no ABS. Wasn't a huge deal.
I sent the ABS module to ABSFIXER, had it repaired, and am getting ready to re-install it. Not sure I'll have a chance to bring the car to a dealer to have them flush/cycle the ABS system, if that's even needed.
What can I do to flush/cycle the ABS to make sure there is no trapped air? Is it as simple as getting into ABS on the street several times to purge any air that may be in the system? I planned to do a full, normal system flush/bleed afterward.
Assuming all you did was remove and replace the EBCM the BPMV remained sealed and no air was introduced into it through the master cylinder or one or more brake caliper cylinders.
You can do a normal bleed without worrying about the little bit of old fluid that will be caught behind a valve or two inside the BPMV. There are some Autel OBD scanners that have the ability to command the BPMV valves to let you bleed every last bit of fluid out of the BPMV.
Bill
#1792
It might have to do with your tire diameters if you're running a square setup, but it can also be from having pads that have too much friction (too much bite). Also don't take this the wrong way, but a lot has to do with the driver being too aggressive on the brake pedal. I know auto-x requires a different kind of aggressive driving than road course racing, but in my experience the guys who are getting heavy into the ABS are slower than if they drive smoother and just get into it occasionally.
So no, I take no offence to my driving style. It's no Camaro by any means and I will 100% need to learn the C5. Still surprising how sensitive it is.
#1793
Pretty basic braking question...
Those of you with APRacing brakes - What method are you using to push the pistons back so you can replace the pads?
Also, I've pretty much disintegrated the dust boot on the OEM C5 rear calipers. Not terribly worried about it since this is a 95% track car and will likely leave it for now. However, I am a little concerned about the inner seal. I imagine it's fine, but curious on another opinion. I figure I'll have to rebuild the caliper after this season. Not sure I should be concerned about the seal at this point yet or not.
#1794
I use this type of caliper piston spreader with the AP calipers:
https://www.ebay.com/itm/Pro-Disc-Br...item5417d4aecc
As long as you clean the piston off with a good dose of CRC brake cleaner before you push it back into the cylinder there shouldn't be any issues due to dirt hurting the seal.
Bill
Bill
mikeCsix (05-10-2019)
#1795
Bill
Bill
#1796
I use this https://www.girodisc.com/Caliper-pis...er_p_5970.html . You'll still need a spacer, or worn out pad, when you put in new 25mm pads. The Girodisc spreader won't spread it quite enough. Otherwise it's a big time saver. Since I swap pads a couple of times a month it's worth it to me. If you're just doing it once or twice a season it's probably a waste.
#1797
Bill
#1798
With the caliper bolted in. Without using the tool to push the pads back it is impossible to move the caliper. The pads have ears on them at top and bottom and I use the tool paddles to spread the pads far enough to get the pads out then insert the tool in the caliper to push in 4 pistons at once and then two pistons for a 6 piston caliper.
Bill
Bill
#1799
placement of calipers
i see all combinations of calipers in front or behind the axle in front and rear. sometimest they are at 45°. i have not seen any on top or bottom.
how does the caliper location influence wheight transfer or squat and maybe roll when braking?
#1800
Former Vendor
Old C3 is nearly on top. And a few Sport Racers are mounted completely on top.
Read some info years ago about braking effects on the vehicle when in such "odd" places but can't recall where. I think however at the end of the ultra tech discussion...it didn't matter enough to make any difference.
