Does anyone have any braking questions.
#1821
Received 8,928 Likes
Thank you very much Todd, really helpful. I don't think it's related to bleeding since the same thing is happening on all 4 corners and I've bled multiple times. But piston binding is a possibility - the DL is not very expensive caliper, so not opposed to buying new ones but is there a solution for current ones (rebuild?). Deflection - that would not surprise me at all. On my C5 I had AP racing brakes on front and am use to that type of quality. The DL leaves a lot to be desired in comparison.
Bill
#1822
Former Vendor
I've beat the crap out of them on dirt and pavement on my own ~1500lb car (with four wins on Pikes Peak where braking sorta matters) and have had no wear issues. I think Bill hit on it also regarding the pad wear plates being a good investment. Seeing that the DL has a very thin (again that right app issue) pad you can wear them down rather quickly which will lead to more rapid tapering and possible binding. *The DP6 addresses all that with a fixed bridge, roughly 30% more cubic inches of pad and a differential bore design for taper control.
I don't know how they are mounted or to what so when I speak of defection I'm even more suspicious of the mount plate than the caliper itself. Could be nothing, but I have not looked at one so can't say for certain.
Just more food for thought. Need something feel free to give me a ring.
Todd TCE (06-06-2019)
#1826
Hi Johnny C
Can you help?!
The other day while backing out of the garage I heard a pop on the rear wheel like a caliper was stuck and then released. As I drove I could smell a burning brake smell. The peddle was going lower and lower every time I stopped and then finally went all the way to the floor, the light came on and I was left with no brakes. I got it home and checked the fluid and the master cylinder was still full.
The next day, the peddle was back and the light was off. I had the car towed to a shop but they can’t find the problem. I know it sounds like a M/C problem but that would not cause the brake burning smell?
sal
sal
#1827
Can you help?!
sal
sal
#1829
#1830
I believe that MikeCsix's observation is correct. Since the '88 activates the rear brakes when the parking brake lever is applied, it's possible that the rear pads have been dragging due to an incomplete release. (I'd check the emergency brake's mechanical cable linkage and slider linkage on both rear brakes to make sure the rear brakes are releasing properly.) If you slowly heat soaked the rear brakes (or just one brake set that didn't release properly) to the brake fluid's boiling point, you will get the condition MikeCsix described. The burning brake pad smell was probably a stuck pad heating up the brake fluid to the point it boiled again. (Once boiled, the brake fluid must be changed out or it will continue to boil with normal use.) Hope this helps!
#1831
I'm looking for a rear pad for my C7 Z51 for the track. I run PFC fronts. The PFC rears I received were too long for my rear caliper (prob designed for the Z06/GS rear). I have been running the stock rears, but I want something that will hold up better. I've been working on stretching out my braking points and using more pedal.... I need more pad on the rear. Suggestions??
#1835
Supporting Vendor
St. Jude Donor '11,'13
Check out the Carbotech XP8 or XP10.
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP8™
Carbotech™ XP10™
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1836
#1837
Hi,I’ve been using DTC70/60 combo on the stock calipers. Switched to AP racing calipers in the front and use Ferodo D1.11 on those so I matched these with the DS1.11 on the rear. The combo works great for me. I have used Carbotech XP12/10 but these seem to wear quicker. So my recommendation yo try DTC70/60 first (cheaper option) and DS1.11 if you feel the Hawk don’t bring you what you want. I do agree that Ken from KNS can help you with detailed comparison. It is all about compromise between initial bite, wear, and temperature range. I have seen star graphs comparing the most used racing pads but could not find it anymore.
By the way the stock non ceramic rear brakes for the GS/ZO6 are the same as far as I know so these should fit your caliper as well.
Hope that helps
Hope that helps
#1838
I have found the website with the compound comparisons. It is not complete and PFC01 not Ferodo 1.11 are on it but it is a starting point for selection.
https://www.racetechnologies.com/brake-pad-comparison
Good luck
Good luck
#1840
Rotor question from a DIY
In changing from Brembo semi-metallic pads to carbon ceramic pads, is it necessary to scuff/sand the rotors?
I have gotten conflicting info to scuff or not scuff. Need some clear direction.
(C6 2013 GS)
THANKS!
(C6 2013 GS)
THANKS!
