Michelin Pilot Super Sports on track
How many track days have you gotten out of your MPSS'?
I have 14 on mine and the tread appears to have enough for several more but the traction in brake zones seems to be non-existent.
I don't know how many days I have one mine, but they have been wearing well for me. My issue is I'm definitely wearing the outside of the tires more, especially fronts. I see myself getting to cords on the outside and still having tread on the rest of the tire.
I have about 9 on mine and about 6k street miles. Tread is still abundant, but they get very greasy after a lap or two. Should be just fine for the street, but I'll be ordering a new set before my next track weekend. Great all around tire.
Wow, that's pretty good. I got 5 days out of mine but that was ~16 hours of track time. They were doing ok but like the Cup2's once they start to go off the car pushes like mad. I tend to slide the front a lot once that happens and they wear out very quickly from there. Here is what my last set of front's looked like at the end.
I count about 22 hours on mine, ~ 2.1k track miles, ~ 8k after adding in the street.
Are these tires from the C7 Z06?
Same here on the tread and the grip. Although I have slid all around the last 2 events, I attributed that to very high track temps. As a proxy, the one time I checked the paddock it was 127*. The brake zone grip hasn't been there all year.
That's some impressive wear - mine don't look anything like that. Until recently I ran modest front camber ~1.5*. Last 2 or 3 events pushed it out to ~2.2*. Yours look like the latter.
Like I said before, once they reach a certain point of wear they lose grip dramatically on the fronts. Once I start sliding the fronts it pretty much peels the tread block off the tire in short order.
I'm going to run Hoosiers starting this weekend I'll be curious to see how they wear on this car as it's the exact same setup I run on my C6Z. On the C6Z even with -2.8 camber front and poly bushings they will eventually wear out the outside shoulder.
I haven't run those tires but had those issues before. I learned that just because the tire has plenty of tread left doesn't mean it hasn't been heat cycled out. Then your grip is done.
They are great tires for the rain, I drove on a wet track once and it was still really slippery, but a lot better than I would have thought. They are really really greasy after 20 minutes. I was thinking about scrubs, but then I would have to tow on a trailer that I don't even own. Not to mention it would be more costly on the brakes/rotors, as well as the diff.
Besides pilot sport cups, is there anything in between PSS and full slicks?
I quickly realized that one to two cars get eaten by the track at every event I attend. For me a 25k car isn't something I can laugh off as I toss the keys to the scrap metal guy. Since the probability of me winning the lottery 1:a billion is less than my car getting busted up 1:100 I buy insurance.
Experience:
Kumho XS - 17 days, still had what appeared to have enough tread to last a day or 2 more and some grip left.
Nitto NT-05 - 6 days, plenty of tread, no grip left. In fact they were at least partially responsible for stuffing it into a tire wall (had insurance then and always do).
MPSS - 14 days, a fair amount of tread left, little grip left.
A lesson that I am just beginning to figure out.
Experience:
Experience:
Front: -2.20* camber, 8.50* caster, 1/16th total toe out
Rear: -1.40* camber, 1/16th total toe in
Re: tunnel plate - I did, although back when it was installed, I can not profess to a finely tuned rear-end dyno so it could have been a placebo effect. I would still do it again if I had a do-over as I recall a possible placebo effect w/r/t interior temps as well.
I am running a square 295/35-18 setup on a C5Z with neg 2.2 up front and neg 1.5 out back. Usually plan on having the tires at 35-36 lb when hot so start around 27 lb cold.
I found them easy to drive and wear is not bad but they clearly overheat after a few laps and get quite greasy and slower. Not really sure if they are heat cycling out but lots of treadwear left after 7 track days and 1400 street miles.
Interestingly (but not surprising) they are sig faster with cooler track temps.
Very good in the wet but overall dry grip is no match for Rivals or RS3s and likely compatible with the 300 treadwear rating.
Would I buy them again? Not for Time-Attack but might be good for Chump Car.
