Front wheels locking up
I have a C6 coupe that has been upgraded to Z06 Calipers, two piece rotors, SS lines about 10k miles ago. Very happy with my brakes.
Recently changed to AX6 pads from carbotech for road racing and find I can now lock my front wheels unless I ease into the brakes like I was in rain.
I bedded the pads and new rotor combo right after install, is this a normal result of an aggressive pad or a reason to re bed the system?
Thanks.
Thanks.
I guess the first question people will ask is what tires are you running?
I'm actually having same problem with stock C5 brakes, Raybestos ST-43 pads, and R888 tires. I have to be super delicate with the pedal to not engage the ABS.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
When my ABS unit on my C5Z failed I sent it to ABSFixer. I no longer engage the ABS to any detectable degree. I don't know if it is because of possible better ABS engagement now or if I have learned to conserve more momentum into a turn or, possible, a combination of both. BTW, I run upgraded 6 piston Wilwood calipers w/ Hawk DTC70's and Hoosiers (with the occasional R888's or Nitto 01's).
Supporting Vendor
St. Jude Donor '11,'13
Thanks.
Thanks.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
I do half mile drag racing and while I use a chute for 200mph+ stops I wanted a stronger pad to slow me down. Not complaining that I have too much braking power just want to be certain I didn't cause this through my bedding procedure
Anticipated response: How did you bed?
Per carbotech I got out on the road and warmed the system up with a few miles of street driving followed by highway. I did 8 60-5mph hard stops until I noticed fade and brake smell. I drove for 20 minutes highway without stopping or using brakes at all
AX6 was their recommendation.
if your front brakes are locking up it is from too much front bias. remember that brakes work as a system, pads and calipers are components. so we will need to find a balance that works with your system. I would look into some higher temp pads. being that your doing 200mhp runs i wouldn't mess around with autocross pads i would go for a full race pad.
A6x has a max operating temperature of 1000*, i've seen 1000* on a car going 1/2 that fast. mind you drag racers drag the pedal, so that can multiply the temperature by 4.
I too just went to a more aggressive pad, and would engage ABS on the front at a much softer peddle pressure then I was use to. Give your self some time to adapt to them. My old brake set up was a total street system.
Mark
Mark
this is why i hate carbotech. transfer layer washes away easily. you'll need to go threw the bead in process (and let them cool) every time before you use them.
No to race pads, I street drive this car about 6k miles a year and will start making runs on the tail of the dragon
https://www.corvetteforum.com/forums...questions.html
here is some light reading on how brakes work.
do you know what temperature a rotor needs to get to to dissipate 200mph of energy with a 300lbs car?
I began to hot spot which was the indication for a chute
Perfect recommendation, thank you and will do
