Rear break pad issues
I have a 02 ZO6 that is completely stock that I take to HPDE events. I am running carbotech xp10 on the front and XP8 on the back. After six events the rear pads are down to nothing. The fronts have some life left but not much. No way could I use the pads on the front for another day. This seams completely backwards to me. It’s my understanding that usually it’s the front pads that will get used up first not the back. I turn off the active handling when at the track so I do not think that is the issue. So my question is why would I be using up the back pads before the fronts? The rotor wear on the back is also not that good and I am going to have to replace the rear rotors again after only six track days. The fronts however are fine.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Are you running in Competitive Mode or full off? I don't have a C5Z but my understanding is that competitive mode turns off traction control but not the active handling. It sounds as if this could be burning up the rears assuming nothing else like a bad fluid bleed, or cooked front fluid resulting in a rear bias.
Valvoline Syntec for the brake fluid! has a high enough boiling point that is you boil it in a 20 min session you need more air flowing over your brakes.
Used to be about $12 a quart.
If you boil it with air over your brakes then go to the expensive stuff
I have run that combination, and got approx. 2 weekends on them. The rear pads are small and the rear tires/ wheels are large relatively heavy, have a lot of traction and even though the Vette is front biased the rears will wear fast. Also the 10/8 combo is considered by many to be insufficient for the weight and speed of the Corvettes. I think that you have gotten very reasonable wear from the pads.
Ok thanks I will give the Valvoline Syntec a try.
I have not run the XP10/XP8 combo, but ask if the XP8 compound is softer. I think it is. If that is the case it would make sense for the softer compound to wear faster.
I get there is more front bias so the fronts would wear faster, but with A/H completely off (no competition mode), there is no other explanation unless both rear calipers are sticking. Trail braking is still using the same brake bias.
Using the same set of pads for 6 track days is getting a lot of life out of them (2x normal).
Not a direct comparison
Because I run a C 4, similar weight to you but less HP. But I also run XP 10 / 8.
Anyway, my experience matches your expectations: I get about 6 HPDE days out of the fronts and about 12 with the rears. My rear rotor wear is less than half of that experienced in the front.
