C5 wheel travel per shock travel?
Does anyone know the ratio of wheel travel vs shock travel on the front and rear of a C5?
I've searched (both google and here) and got nothing. I found some information on motion ratios for springs, but nothing on the shocks.
Location: If you don't weigh in you don't wrestle Road America
If the motion ratios that you've found are for a coil-over car then shock and spring ratios would be the same.
Check out this thread:
https://www.corvetteforum.com/forums...sion-math.html
Post #7 by gkmccready
So .69 front and .6 rear
For the shock (as in with coilovers), the front is approximately 0.69 and the rear is around 0.71 at droop and 0.53 at bump -- call it 0.60 average. If you take the spring off and measure shock travel versus wheel travel you'll be more accurate for this case.
