Gil Smith Alignment Turn Plates - Any Good?
The price is right, which usually means Chinese junk. Anyone seen these before? $90 for straight up turn plates and $200 for plates with lateral movement.
http://gilsmithracingfab.com/alignment-turn-plates.html
They appear to be marked at the 15 and 20 degree points too.
I've tried all the common ways to check caster garbage bags and wd40, thin pieces of laminate with salt and they're all not user friendly. It's time for a set of turn plates and I have looked at these, I'm in the same boat I would like to hear from someone who has used them. Supercharged 111 why don't you buy some and report back to us?
I almost bought these, left a message with him and then found some large lazy susans at my local hardware store that had a 1000lb rating and made my own. They work great, only 3/8" thick. I think his would work fine if you don't want to make your own.
Harbor Freight had some turn plates several years ago, i believe I paid less than $150. I have used them and made some 1x12's to get the same ride height for the rears. Other than being very heavy they worked very well. When corner weighing/aligning, I had to use some old rotors in the rear to zero out the scales--also have raised ramps for the scales.
