Rear Toe Links (Tie Rods)
I'm sure this topic has been beaten to death but I can't seem to find the answer i'm looking for and I'm about to just try the parts and try.
So the part number for the rear inner tie rod (88955489) is harder than hell to find apparently and from what my local dealer tells me they are not available at the moment. Now I did some sleuthing and stumbled across the C6 tie rod (88955490) which utilizes the same outer tie rod (88955488) as the C5
The round about question is does this inner tie rod fit the C5 or is there an insurmountable difference in either the length of the rod or mounting provisions? I Imagine it can't be to great considering all of the rear bumpsteer kits that replace the whole link seem to be 97-13
Platinum Supporting Vendor
88955489 C5 Corvette Rear Toe Link
I experienced the same issue as other's have. However, you may want to check OEM Parts Quick. I was wary of using GM PN 88955490 in lieu of 88955489 give some changes in the other details from C5 to C6. I found and placed orders for 2 each 88955489 at $127.00 w/shipping out of GM warehouse in Athens OH. Delivery date is March 15, 2021. The picture is incorrect: It depicts a steel type sway bar link. However, description is as follows:
Spare Part Information
This part is a link kit, rear suspension adjust, for Chevrolet cars. It fits for Chevrolet Corvette for the U.S. from 1997 to 2004. It's a genuine General Motors merchendise product with an OEM part number 88955489.
A sway bar link has no adjustment, therefor the picture is incorrect as PN and item description are same.
I hope this helps those of whom have been searching for an answer to this issue.
Thank you for your reply! Any information will help and be much appreciated. I have been reluctant to disassemble the rear tie rods during the driving season, knowing the availability problem with stock replacement parts could cause the car to be down for quite awhile. My hope was to find enough information online from suppliers and the Forum to develop a game plan for possibly fabricating or modifying what I will need.Thank you again very much!
