Lost a pad pin at Sebring Sunday
13 GS, spit out a pad pin yesterday.
Has anybody found a cure for this issue? I know BBK is the way to go but not feasible for me at this time.
Received 8,918 Likes
The only thing I can think of is using some aluminized (shiny) duct tape over the pins to keep them from turning. Take a strip of it and run it along the caliper covering the pins like you do the wheel weights on your wheels.
Bill
Bill
speedwaywhite (04-26-2016)
Stock caliper I take it? Had that happen a few times. Took all the pins out and put red locktight on the threads. No problem after. Mark the bolt head and caliper for an easy visual inspection to check if they are backing out.
The heat will make the stock locktight fail and bolts will back out.
speedwaywhite (04-28-2016)
Thanks for the reply and good idea! Yes, stock calipers (not the greatest design to be sure). I hadn't considered using locktight, assumed it wouldn't stand the heat. Are you using stock pins? I have be using after market pins with 10mm hex, I found the stock torx head pins to be tedious. Do you think pins should be replaced periodically? I have 18 track days on the pins in use now.
Whenever you get the opportunity or want to, upgrade to a BBK. Money well worth it if your going to track the car for a while.
<br >You are lucky it didn't get into your wheel spokes. Found out the hard way on C6Z wheels they hit the spokes when they back out.
I used blue locktite and tightened the crud out of them warm. They will need replacement when the bearing surface wears out.
Check your transfer tube is tight when hot while your at it, had one of mine loosen up and got fluid everywhere. <br >
I usually leave mine in as well, I am running one piece Carbotech on the street and Cobalt X2/DBA4000 for track duty. I do torque them after each brake change.
I am considering a C7 GS, waiting for pricing an availability on the new model before I spring for a BBK kit.
I will try the red locktite ands also mark the head so I can see movement. I have had 2 of these calipers replaced under warranty for leaking bleeder screw so, I can relate to the mess it makes.
