Reman calipers
Reman calipers
I'm looking at upgrading my base c4 brakes to the j55 option and I'm having trouble tracking down some calipers. Do any of you track guys use remanufactured calipers from places like rockauto or advance auto, Napa etc.? They run about the same price as used j55's in the classifieds even with the core charge. Are there any brands or places I should look out for? Thanks in advance.
Last time I used a re-manufactured caliper was on a beater 99 Pontiac. The surface that the banjo fitting bolted to was as cast and I had a hard time getting a seal with copper washer.
I would get some used J55 calipers and rebuild them with Doug Rippie stainless pistons. Call DRM ans see what they recommend. They used to sell the 96 Grand Sport calipers as an upgrade for C4 cars.
Are you going to track the car?
After looking around only advance auto has front left and right remans with brackets ready to go, other places only have one or the other or have them without brackets. I would say if I couldn't get one to seal it's defective and I would return it. Worst case I have access to a mill and I could solve a small problem like that, I'm mainly wondering if some companies cast calipers with lower grade aluminum or something else that would make them not ideal for track use.
