Is it a wash between the C5Z and C6Z in AS?
I have been autoxing for 3 years now and am thinking of moving to a corvette next season to race in AS. I was set on a C5 Z06 but as I started looking at the recent results for this year it seems most of the top guys are running C6Zs. Are people finding the C6s much better with the current classing or is it pretty similar? I know I am not the fastest but I do take autox seriously and dont want to be kicking myself for not saving up a bit more and wishing I had a C6Z.
I was able to find a few threads but many are dated and with class rules changing frequently I was hoping to hear thoughts from experienced drivers on going from a c5z to a c6z. Thanks a lot and hope to join you guys soon!
c5z = better gears
c6z = better (bigger) tires/brakes
The following 2 users liked this post by froggy47:
BrianCunningham (07-14-2016),
phloozy (07-14-2016)
Thats interesting to know. As a pseudo beginner gearing is really important to me. I currently run an 05 STI and I am constantly shifting 2nd-3rd or just banging the limiter in 2nd and I hate it. Gearing is one of the reasons I wanted to switch cars. What's wrong with the gearing in the c6z that makes the c5z better?
I don't think you're giving anything up by buying the C5Z. Nominally lighter and a bit narrower. Not sure that I've ever seen one campaigned seriously, but on paper the C6GS is the better autocross buy than the C6Z because it has normal gearing and thus better thrust even with less power.
Yes, they're really pretty much a wash depending on the coarse. If cost is a concern, go with the C5Z. Strano can help you get it setup to a nationally competitive level. You'll have about $10,000 less into it than just the purchase price of a C6Z. You'll also save on tires and brakes over time without having to worry about the heads.
The following 2 users liked this post by dhowdy:
The C6Z (and GS for that matter) in AS will be able to improve it's gearing a bit by using 18" rear wheels and the 335-18 Rival S, almost an inch smaller in diameter than say an A7 345-35/19 for SSR (no +/- wheel allowance in SSR).
Thanks for the help guys, just put a deposit on a mint 2003 C5 Z06 with 15k miles. I can't wait until the first event. Will be giving Strano a call soon, also nice being local to him
Not sure if it's relevant, but I went in AS a couple of months ago with my 02 C5Z and ran a 54s on our course. A 2010 Grand Sport ran consistent 48s.
Not sure if the 2010 shares much with the C6Z, but I was amazed at the dude's times. I believe some of my mods were illegal in AS, and I'll be jumping into CAM-S next time I race.
Except that I have both that are bone stock and used my DL1 to get real #'s and this is what I got.
https://drive.google.com/open?id=0B8...TRURkI2Yk9BUWs
Ramo7769 (07-18-2016)
From a tires/brakes/suspension standpoint they are identical. The only difference is the GS has less power and is slightly heavier. Also recently I learned my magnetic ride equipped manual 2013 GS coupe has a FE5 sway in the rear. I'm in the process of confirming if this is the ZR1's rear bar and why my car has it.
You should recheck your statement. A c5z and a c6 gs do not have the same tires/brakes/suspension.
The only other variable is my C5Z has a lot more use and abuse on it. I haven't had it on a dyno, but I have no reason to believe it's down on power.
