which impact wrench?
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Not only the power but the battery life is amazing. I know I have gone over 3 months and had over half life left. It appears to deliver full power even when low. I may need to get some of the compatible tools in the family, also.
Yes, I got the 300ft-lb one a couple of months ago and I really like it. I typically break the nuts loose with a breaker bar before I lift the car and then use the impact to run the nuts off but the few times that I've forgotten, it hasn't had a problem breaking them loose.
Joshboody (07-19-2016)
I have the Ryobi P261 18V which is the battery format I'm committed to. It works pretty well, will loosen 100 ft lb lug nuts with an impact socket directly on the anvil. Like I noted in a previous post, adding a standard extension in my experience reduces torque at the lug nut.
I bought a $99 one from Pep Boys and it pulls my lugs at the track that are torqued to 100 ft lbs.
It will only do it 6-8 times(wheels) on one charge though.
https://www.pepboys.com/product/details/9343447/01551
Another Milwaukee user here. I have both the high torque (2763) and the 3/8" compact version (2754). Both have no issues loosening lug nuts. The 2763 zips off crank bolts easily as well.
I bought an Ingersoll Rand cordless impact 7-8 years ago. It's their 18v lithium pro IQ something like that. I've never had an issue with it. The battery last a long time, has a nice carry bag and has had no issues breaking my wheels loose when hot. I torque to 100ft lbs when cold.
I just got the Porter Cable 20V set, it's great around the house and the impact gun can sometimes do lugnuts, but not reliably.
Kobalt just came out with a 24V set that is priced really well, and seems really impressive on paper. It's also got legit 1/2" impact wrenches and 3/8" impact wrenches. MAJOR torque on them. Supposedly the Lowe's NASCAR team uses them around the shop.
I've been debating on switching over. My PC 20V set is great for house stuff and has like every useful tool, whereas the Kobalt line isn't full featured yet. It's been a tough decision.
We use IR in the shop because they are some of the stoutest impact guns out there. We have a fleet of heavy trucks and we use them to spin the lugs on/off the big trucks when we have flats on the side of the road.
(we are street sweepers so we get a lot of flats)
I also use them to spin the lugs off and on the extended ARP studs on the race cars because doing that by hand really sucks. I NEVER use them to tighten the lugs though. Only spin on till they touch the wheel.
outsideline (07-23-2016)
On the DeWalt 18V Impact Wrench, you need to make sure you get the XRP batteries with it. I have had one for several years and when I first bought it, it came with normal batteries and did not have as much "oomph" as one my buddy owned. We noticed that his has XRP batteries and that solved my issue after changing to them.
http://www.dewalt.com/en-us/products...ry-pack/dc9096
Another option is a new 24V Li-ion Impact Wrench from Kobalt sold at Lowe's. I bought one of these a couple of weeks ago and it is very impressive. I am holding off using it full time until my DeWalt is dead (which may take several more years). I actually need to practice with it to see how long/hard to run the lugs in to get close to my normal 95lbs of torque as I am afraid it will overtighten.
http://www.lowes.com/pd/Kobalt-24-Vo...nch/1000061641
If I were buying new, I'd get the Kobalt.
Ingersol rand or the m18 can't be beat IMO.. I have the IR and it goes everywhere I go, and will do **** I can't even think about with my snap on air gun...
https://www.amazon.com/Ingersoll-W71...ol+rand+impact
I got mine "used" on amazon for $350 with 2 batteries
#34
Love my 1/2" Milwaukee. Want to try out the new 3/8", as it may do everything in a smaller package.
Used a lot of 2nd rate tools in my life of wrenching and its nice to have something that works as advertised.
#35
I love mine. I tighten my wheels to 90 ft lbs and have never had a issue removing the nuts.
btw - I hope no one is using this type of wrench to tighten the nuts. Just sayn'.
Richard Newton
Lug Nuts & Studs: More Than You Need to Know
#39
