Cool-A-Clava
For logistical reasons I can't try mine with water for a couple of weeks. My engine is out and my garage a mess.
It 's fittings did not match my FAST shirts which are pretty old so I just ordered the right fittings from mcmastercarr.com
Captain Buddha (07-24-2016)
WOW! Best thing I've bought lately! If you're on the fence, stop....go buy it!!!
Some folks thought it might require a
larger helmet - it is so thin I actually put it under my balaclava. Helmet
fit just fine and everything was very comfortable.
SunnydayDILYSI (07-28-2016)
I'm so glad I found this thread. I've been on the fence and have considered buying a new helmet with a blower system or integrated coolshirt connections. Looks like I'll give this a shot first.
For those who've already tried this, do you find yourself wanting a blower system too or does this completely solve the head heat problem?
If you are looking for just a head-only cooling system, new offering:
https://www.teamdi.com/product/cools...d-cooling-kit/
What size pumps are you using with both cool shirt and clava? I have a 500gph pump and when both shirt and clava are hooked up, it just barely puts enough pressure to move water through the system. And if I bend the clava just a little near the entry/exit points, it cuts off the flow entirely. I blew out all my lines to make sure there wasn't any obstructions. Maybe I just need a bigger pump?
Just an update - used it all day in 95 degree heat. It's amazing. Worth it's weight in gold. I guess the only slight downside is that my head was freezing from time to time and I was actually tempted to turn it off during the race. But honestly at the end of the race waiting in impound I usually take my helmet off as fast as possible and guzzle some water. This time I just sat there cold and refreshed and didn't even bother taking my helmet off. Go out and buy one now.
Usually Before race I pour ice cold water on my head, chest, back, left arm which helps for a bit also wear regular balaclava to keep sweat out of my eyes.
FL summer heat is brutal and the DP has closed Windows & now much for ventilation.
#33
Sounds tempting. In the DP I wear a vest that's also used by ARMY Apache Pilots. It works ok. Will this Cool A Clava work alone or must you use it w cool shirt ?
#34
I tried mine this weekend but gave up after one session. When I was all belted in it kept crimping the host to the coolaclava which cut off flow to everything. The small hoses it has are just much easier to crimp than the cool shirt ones. I'll have to spend more time trying to work on the hose routing.
#35
Back from the dead!
I think I want one now. Curious how many others have tried it successfully or otherwise as poorsha experienced.
