Toyo R888R
Old 05-23-2017, 03:54 PM
  #181
Suns_PSD
Suns_PSD's Avatar
Originally Posted by TRANS DAMM
I love the rears. My issue is with the fronts. My 285's rub and pass the fender ever so slightly. I'm wondering if the old 888s in the front might solve my issue.
Have your wheel turned till they rub (preferably on ramps) get a flashlight in there, and make a decision from there.
I can't really compare my set up to yours just because I have a different car, different camber, and probably different offset aftermarket wheels. In my case, it all clears except my tires rub my brake duct a it during hard corning maneuvers. It also looks just right with the top of the tire tucked in about 1/2" with some negative camber.
You are currently running 285/ 35R18s R888Rs up front correct?
Well a 275/ 35R18 R888R would be 10 mm less wide (overall so 5mm per side) and also about 3.5 mm less tall (look up exact dimensions on Toyo website). Maybe that's enough.
Then the 275/ 35 R18 in the older R888 would be narrower still.
Too top it off after that you might want to look at other tires that naturally just run more narrow.
Good luck.
Edited: Okay, just saw your photos. Just pull your tire and trim that plastic away. No reason to swap tires over that imo.
Old 05-23-2017, 03:57 PM
  #182
TRANS DAMM
TRANS DAMM's Avatar
Received 1,156 Likes on 531 Posts
Good luck.
right now Im running 295/30/19s on a 19X10 wheel
Old 05-23-2017, 03:58 PM
  #183
Suns_PSD
Suns_PSD's Avatar
Originally Posted by HC Mechanic
I know right!!??
Is that a standard C6 with a 345? What size wheel is that your running?
I’ve got a standard body C6(rear wheel 19 x 11) as well and looking to replace my Mich. Sport Cup’s with some of these R888R’s.
Making 575hp at the tire N/A is just too much for the Sport Cups.
I will say though, they were much better when I origionally put them on the car...probably got hard over the past year.
My car is a base Z51 '08 model car. The car has a Ligenfelter mini tub kit installed. They are 12" wide rear wheels in some weird offset specifically for this tub kit.
Old 05-23-2017, 04:02 PM
  #184
TRANS DAMM
TRANS DAMM's Avatar
also more then the rubbing at this point it sticks out passed the top of the fender by about 1/4" and I don't know how much junk its going to toss up at the side of the car. I think at this point im def over the 295's. im thinking about the 265/30/19 r888r's. stock was 285/30/19.
Old 05-23-2017, 04:03 PM
  #185
Suns_PSD
Suns_PSD's Avatar
Originally Posted by Quickshift_C5
What in the world are you guys doing out there to not get traction with these tires with only 600rwhp or less?
I shine mine with hydraulic oil on the tread, looks killer for the car shows. Just kidding.
I think that there are some regional differences in how well the local pavement hooks up and how much oil it has saturated in to it. I also think certain set ups pick up rpms much quicker off the bottom and will tend to break tires lose more easily. I mean, in the Super Chevy test on LS3 cams some years back the smallest cam made the most average power up till about 5.5K rpm. So some of these big cam set ups with high horsepower numbers might actually be a bit soft and unresponsive off the line. However, I sure would like to find out and would like my own 650 rwhp NA LS7 for testing!
It's just a guess though.
Old 05-23-2017, 04:06 PM
  #186
Suns_PSD
Suns_PSD's Avatar
That's not a good look.
Every tenth degree of negative camber will bring in the wheel about 1/10 of an inch. Add -.5 camber, which is nothing, and that wheel will be tucked in another 1/2" easily.
But yah, it sounds like smaller tires are the ticket in your case.
Old 05-23-2017, 04:09 PM
  #187
TRANS DAMM
TRANS DAMM's Avatar
what do you think about going down to a 265/30?
Old 05-23-2017, 04:41 PM
  #188
Suns_PSD
Suns_PSD's Avatar
Um, I think that's a tiny tire compared to what you currently run.
A 10" wide wheel looks really proper with a 275/35R18 if it clears everything imo.
Old 05-23-2017, 04:50 PM
  #189
TRANS DAMM
TRANS DAMM's Avatar
its a 19" rim. the 888's don't come in 275 in 19"
Old 05-23-2017, 05:19 PM
  #190
Quickshift_C5
Quickshift_C5's Avatar
Don't know about all that, seems like a lot of speculation. I was able to hook at the 1/2 mile last year on a rock strewn unclean bumpy runway. You can even hear the tires spin for a very brief moment hitting bumps when wide open in 2nd gear and it still instantly grabs. You should be able to hook as long you aren't slamming your foot to the floor. Give the tires a chance to do some work.
Old 05-23-2017, 06:13 PM
  #191
HC Mechanic
HC Mechanic's Avatar
Toyo R888 305/35/18
Huh, based on your feedback it’s got me thinking..
Maybe the key is getting rid of the little sidewalls(19” r. wheel), and pickup some 18” x 11” rear wheels.
Old 05-23-2017, 07:15 PM
  #192
Suns_PSD
Suns_PSD's Avatar
I use to road motorcycles many years ago and I'm smooth as can be with the throttle clutch and brakes just by nature.
Understand that my z51 transmission combined with my 4.10 gears makes my car accelerate like it has another hundred horsepower in the first 3 holes.
Old 05-23-2017, 09:53 PM
  #193
Quickshift_C5
Ouch, now it makes more sense. That's a lot of power with 4.10 gears. WTF man.
Old 05-26-2017, 01:55 AM
  #194
wtb-z
wtb-z's Avatar
Has anybody put track days on these yet?
The old R888, in my experience, was
* Not fast on the first heat cycle
* Fast on the second heat cycle
* Fairly hard fall off after that, bad by 1/2 tread, stone dead after 2/3rds tread
* Marshmellowy when new, indifferent when old
* Hard to pin down the right tire pressures on
Wondering on what is new and what is different, if anything.
Old 05-26-2017, 11:58 AM
  #195
harrydirty
harrydirty's Avatar
What air pressures were you running?
Old 05-26-2017, 01:42 PM
  #196
Bluefire
Bluefire's Avatar
I have tracked both the R888's and the R888R's.
Both tires liked 40 psi (hot).
R888R's heat up faster, and don't get greasy like the R888's.
R888R's stick better in the turns.
Interesting note: When I was swapping wheels yesterday, I laid a mounted 295x30x18 R888R on it's side next to mounted Hankook Ventus Rs3 305x30x19. The Toyo was ~1/8" taller.
Old 05-27-2017, 01:37 PM
  #197
TRANS DAMM
TRANS DAMM's Avatar
Rare as hen's teeth!
Both are 345/30x19s and are lying on a flat surface. That's the old R888 on the left and the new R888R on the right that is 5/8" wider overall.
I officially hate these tires. My 295/30/19 "R's" were rubbing when everyone else running the same wheel/tire size did not have that issue. After seeing your post I blamed it on the new R's running bigger. So I ordered the older 888s and sure enough my luck sucks. Here is the mounted R to the uncounted 888. ANY IDEAS??
To Toyo R888R
Old 05-27-2017, 01:39 PM
  #198
TRANS DAMM
TRANS DAMM's Avatar
Should I mount the 888 and see what happens? Any chance it's because it's unmounted/not inflated?
Old 05-27-2017, 04:31 PM
  #199
Bluefire
Bluefire's Avatar
Are you at stock ride height?
Old 05-27-2017, 04:49 PM
  #200
TRANS DAMM
TRANS DAMM's Avatar
No. Lowered on the factory bolts
Quick Reply: Toyo R888R
