Radiator: Ron Davis or DeWitts
These types of threads are always going to be all over the board. Where you track and what skill level you are at plays a huge part in this.
I had an '04 Z with Dewitts radiator and stand alone Ron Davis large oil cooler. Running at Sebring in the summer I would see 210-215 water temps and 255-265 oil temps when really pushed.
If you're worried about oil temps on the street I used to tape up my oil cooler with painters tape when I was not tracking and this would net me up to 185 temps around town instead of 155-165.
The radiator still ran the car cool though when driving around on the street.
I run the DeWitts C5 radiator with EOC which I don't use. I have a stand alone DRM oil cooler and between the two I never see water temps over 220 and in the most severe track conditions oil temps hit 270 which I don't consider an issue. My last Blackstone report was excellent. The people I know that run their C5's hard on the track have not had success running the radiator EOC's. I think it's a great idea for a street car and light track use, but under the worst condition (which we all eventually encounter) it will be inadequate.
I have had the DeWitts and eoc and stock fans for over 8 yrs in my dd/track car. I usually run in the advanced group with a 517rwhp motor. 2 weeks ago, I ran VIR with ambient temps at 74* and coolant was at 212. The highest I have ever seen it was 228* at VIR a few years back at the 4th of July week when ambient was 107*. By the end of Sunday, there was only me and another Viper left. In front of the DeWitts, I have the largest Setrab oil cooler I could find, my AC condenser, and the Vararam intake all cutting down on airflow, but the DeWitts cools with zero issues. I know the RD is a solid rad, but hard to believe it is worth $200 more. Hope this helps and good luck with it.
Which setrab core did you go with?
How far in front of the condenser did you place the oil cooler?
Did you do any custom ducting for the oil cooler or radiator?
I have it mounted by 2 angled aluminum strips from Lowes to rad skidplate and up to to of rad. There is probably less than 1" between oil cooler and condenser.
Everything else is stock. I did do the Trackspec hood louvers to help draw out the engine heat:
2 weeks ago at VIR was my first real track day with them, so hard to tell. Coolant stayed at normal 210ish and oil stayed at normal 260ish. Will see how they do in the summer hear.
HTH
Former Vendor
All good info.
I just installed a dewitts, with toc only. I installed huge fluidyne oil cooler in place of the factory Z06 cooler. Then went AC delete. So I got rid of the ac condenser. I have a katech red oil pump and AN-10 oil lines to the cooler. I don't have a clue as to how well it will work yet. My first event this year is at Daytona in April. Engine is 593 rwhp. So lots of stuff to try and to sort. Hopefully my long winter's work and patience will shine.
Has any testing been done to show how much cooler (or more effective) the cooling system becomes if the air conditioning condenser is removed?
Lets base this on the assumption that the condenser has no restriction due to dirt, leaves or anything that will clog air flow.
Interested to hear your thoughts or track experience.
BigMonkey73 (08-25-2019)
Former Vendor
Tom,
I removed the coil on an older camaro I tracked and it made a very noteworthy difference. Obviously a hot coil passes warm air like Tom states but I have first hand experience with this in a situation where cooling was marginal at best with coil, once removed my car ran consistently 15-20* cooler.
#33
You are correct on the C6 Z06(and possibly other models) the AC condenser is mounted directly in front of the radiator thus reducing air flow to the radiator.
#34
I have a Dewitts cutdown (supercharged). HPDE intermediate. 2 weekends ago at Vir was mid 70's temp - coolant was 202. The highest on track i have ever seen is 212 if I remember correctly.
I run a big 72 row oil cooler with remote filter and IR 212 thermostat.
I have personally seen both radiators and my opinion is the dewitt and Rd use very similar cores. RD has fab'd end tanks and dewitt are stamped is the main difference (which means nothing in terms of cooling).
With either radiator I think the key is you need to spend some time sealing up duct work going into radiator to get maximum efficiency.
#36
Maybe somebody here can answer this question......If I decide to remove the condenser and the air conditioning compressor, is there an idler pulley to go in its place or can the belt be routed in a way to bypass the air conditioning compressor pulley if it is removed?
#37
AC belt is a separate 2nd belt behind the serpentine belt for C6s. I think the same is true for C5s.
#38
I run a Ron Davis in my C5Z track car. I have a front-mounted double pass oil cooler feeding right through into the coolant radiator intake area. I was just out at Buttonwillow Raceway this weekend. After pushing it for 20 min with no letup I saw a peak temp of 221F, but avg was more like 117F. It was around 65-70F that day. Here's a vid of me with data logging (I haven't been to this track in a year, and I have a new setup since, so I'm rusty! ):
fruitsalad (03-08-2017)
#39
Decisions, decisions......
#40
My oil cooler uses air from behind front plate. It does not mix with radiator air.
I also sealed the spal fans to back of radiator.. made a huge difference in street driving while in traffic.
