Nitron Racing Shocks C5/C6 Race Pro Coil Over Kit
Former Vendor
St. Jude Donor '13
Nitron has been at the forefront of motorsport suspension technology since 1998. Founded by Guy Evans, the Oxfordshire-based company has gone from strength to strength, producing winning shocks for customers all over the world. Nitron benefits from a design team with an accumulated experience covering machining, materials technology, hydraulics, Sports Cars, GT Racing, WTCC and F1 racing. Many even have experience as competitive drivers themselves. The ability to draw upon such a wealth of knowledge provides Nitron with an insight into the industry that very few can compete against.
C5/C6 R3 Race Pro Coil Over Kit
The NTR R3 system sets the standard for ultimate performance with a design that offers drivers and engineers unparalleled damping control.
3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. Remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping.
The large range of adjustment and quality of feedback allows the experienced driver to fully exploit the full potential of their car. The R3 is a proven race winner and lap record holder across a wide spectrum of international motorsport formulas.
The high-grade materials protect against corrosion whilst reducing weight. Every R3 kit is custom built, sprung and fully serviceable. Titanium and hard-anodized parts are hand built to last not only season after season, but also the harshest of U.S. winters.
Tubes- Nitron tubes are cold drawn multiple times for maximum stiffness and strength, before being honed, hard anodized, and then roller burnished for a precision surface designed to last.
Rods- Rod shafts are Teflon coated and made to Moto-X spec, the best there is, period. All the main structural threads are rolled in (not cut in) removing stress points.
Valves- all valve components are machined from super-hard stainless steel-which means they will last a lifetime, literally
World class compression adjuster- Nitron shocks have the widest range of useful adjustment available on any mono tube gas shock
________________________________________ ________________________________________
* CNC billet machined components
* Completely re-buildable/re-valvable
* Teflon coated pistons for consistent damping control
* PTFE Lined Bearings
* Induction hardened super polished chromium plated piston rods resists corrosion and wear
* Low friction rod seals, double acting rod scraper, and progressive bump stops
* Stainless steel carbide hydraulic hoses with 360 degree Bi-Axis fittings
* Ultra low friction bearings, brushes, and seals for precise damping control
* Exceptional range of fully sealed damping adjustments
* Extensive range of spring rates for Street, Track, and Race applications
* Each shock is hand assembled and backed by Nitron’s 2 year warranty and US based support facility
Our engineers here at XP Motorsports have worked very closely with the Nitron engineers to develop a product designed to maximize the true potential of the Corvette. The combined engineering staff have worked countless hours to bring you the very best coil-over suspension for your c5/c6. These coil-over have been extensively tested on one of our C6 ZO6 at Sebring International Raceway known as the toughest track on equipment especially suspension components for the last 8 months without a failure or compromise. They have performed flawlessly for countless hours and laps. This Nitron equipped car is currently leading the points in NASA Florida Region TT1 & TTU along with setting fastest laps at numerous events.
So when you are ready to step up and make your Corvette handle and ride the way it should then turn to XP Motorsports & Nitron for your suspension components.
Not quite ready for the top of the line race/high performance setup. Then look at the Nitron
R1 Fast Road Shock Kit (non coil over)
R1 Club Sport Coil Over Kit
R3 Club Sport Coil Over Kit
http://www.xplosiveperformance.com/N...it_p_4178.html
Need more info call 888.493.8041
I've been using Nitron 3-way 46mm on my Lotus Elise - and typically lap Corvette's in HPDE's They are the best!
It's a shame i see this now - because for my C6 GS i've recently got the Moton 2-ways, which are very nice too - but i do like the additional adjustments of Nitron and the fact that it is a bit lighter all around...
How much are these?
How do we best handle the rebuild when it is time for that?
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Our Nitron equipped ZO6 takes a 1st and 2nd in TTU this weekend at Florida NASA Sebring event turning 2 minute 16 second lap times. When you become serious about making your Corvette handle. The NTR R3 system sets the standard for ultimate performance with a design that offers drivers and engineers unparalleled damping control.
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
