STANG KILLA goes "racin" Part 2
Verrrrrrry nice job on that car Stang !!! She's a beauty ! Autocross was my game for 17 years in which I won 14 Quebec Championships so I really liked watching your vid.....You could have done those low 46's, believe me....Just some more practice in the car and some better lines and you'll be right there with these guys !
Nice write up and personal touches to your car! I can't leave well enough alone either lol
Keep at it and I have no doubt you'll be faster in this car than your Camaro.
even with the valves open on the stock NPP exhaust, the car wasnt loud enough for me.
i picked up some 3" Dynomax mini race bullets and turndowns
getting the car high enough in the driveway to get the stock exhaust out was quiet tricky. passenger side was even harder than drivers side.
plan was to also shave a TON of weight.
bullets on
turn downs (for what!)
now im used to a loud car, my SS was usually always the loudest car at the track. running a single 12" Dynomax bullet dumping under the rear seats.
but this was TOO loud even for me. it sounded like 7 nascars and 2 prostocks all fireing up at the same time! theres no way i could ever drive anywhere without being immediately pulled over.
the camera could NOT pick up how loud this thing was. shaking the ground. my wife had ear plugs in filming this
bullets on
RHammC6Z06 (09-12-2022)
well i pulled a last minute thrash session and got the stock exhaust put back on the night before and headed back to TWS last weekend.
and after reading a thread on c6 z06 aero lift, i also removed the front air damn under the radiator/nose. it seems to help. wasnt near as dancy and it was the first time.
the auto cross really helped me and i was able to push much harder this time. was comfortable enough to start throttle steering on exits again like i did in the camaro.
was pushing hard enough id have to do a cool down lap for the water and oil temps after 4 or so straight hot laps. going to need to address that.
i found myself doing more of a stop, pivot, and squirt style driving in the Z06 than i did in the camaro, camaro i did more of a flowing miata style driving. but for some reason this car makes me slam on the brakes, pivot, and then gun it. not sure why, but i noticed it.
was the first time ive ever seen the debris flag for low flying buzzards crossing the paths of the cars on the back stretch. that was a weird one.
found out the Z burn 5 gallons of gas for every 20 minute session.
heres some footage compilation of some of the laps.
Lap time update!
backstory: i use race chrono app for my lap timing. worked great in the camaro (glass t-tops).
well i noticed since using it in the Z06 its been acting weird, it will only records 1 to 3 laps per 10 lap session and the lap times were much slower than i had hoped for 2:04 to 2:09 and very random. (1:59 was fastest in camaro)
well during the video editing i mark the time for the start of each lap for each view.
well i noticed one of the lap markers was exactly 2 minutes apart. and then after that the next two were 1:59s! matching the fastest of the camaro!
well when i got to the 5th gopro footage and i had two laps that were 1:57!!! i checked them twice on both cameras that were rolling and i got 1:57 each time for both laps.
i couldnt figure out why i felt like i was hauling and the lap times were so slow. i dont know if the roof is carbon fiber like the fenders and not allowing good GPS signal or what. but a huge relief that the new car has already paid off in lap times! i couldnt figure out what i was doing wrong. stupid technology.
bad news is on sunday on the last session before lunch i got an engine light on the dash, and the car started to run rough, getting progressively worse. so i loaded it up and brought it home.
Lap time update!
well in an effort lower my oil and water temp, and to reduce the high pressure packing under the hood causing my front end aero lift at high speeds on the track, i picked up a 5th gen camaro SS heat extractor vent (part #22828242)
started by checking clearances with some string. there was none. but the strings were 1/2" below the hood line, and plus i forgot the hood has a bulge in the middle.
started by tracing the vent onto a piece of paper, then offsetting in .6" with another line for the actual hole
marking front to back
marking side to side center
pattern cut out and taped into place. 6.5" from back of hood to the start of the opening (just inside under hood structure brace)
traced with sharpie
BUTT PUCKER!!!!!!!! took one deep breath and drilled four 1/2" holes.
tape to protect paint
took my jig saw and cut it out. worked perfect. super clean cuts.
under side. bent up some 1/2" x 1/8" aluminum and bolted it in
painted the aluminum brackets black, and cut out the factory hood insulation for a factory look.
finished!
took it out for test drive on the street and after warmed up you could see a 6"-8" heat wave shooting out of the vents at stop lights. after sitting for a few hours back at home, the hood was stone cold, and you could still feel heat coming out of the vents.
anxious to get back to the track to see if its more front end planted, and if my temps lower
traced with sharpie
finished!
The following 2 users liked this post by STANG KILLA SS:
fruitsalad (04-27-2017),
Junglepeanut (06-03-2017)
WOW that looks like it could of/should of come from the factory that way. I am amazed how well it matches the lines and shape. Great work? How much does the vent cost?
#35
Looks fantastic though. Will be keeping an eye on your results with the cooling and down force changes.
#36
well before buying it, i had heard alot that the C6 seats were crap, and after doing some track time in them they were right.
ive been eyeing some cheap race seats on ebay for a few months, i wanted fixed position fiberglass seats. but sadly when i was finally ready to buy the ones i wanted(NRG) were sold out everywhere.
but these "Invictus" seats poped up that hadnt shown up in any of my previous searches. the shoulder area was a little narrower than i would have preferred. these also came with the side mounts which i wanted. most of the side mounts i saw sold separately were in the $125+ range per seat
i liked what i saw and the dimensions fit so i offered them $175 per seat and they immediately accepted.
when they came in i was happy with the quality.
i took some measurements and drew up a design in CAD for the mounting rails. i kept them low as possible as id read helmet/roof room was an issue.
picked up some 2" X 1/8" steel and after two evenings had the rails made.
kept the rails super low. the rail and bolt head actually touch the carpet. mounted with grade 8s.
painted
mounted
i was out of time and money before the next track weekend, so didnt go to harness's yet. picked up these seatbelt extenders to use as buckles to bolt to the cars floor.
unfortunatly when i tried to bend the hardened steel male buckle it snapped when i went past 35-40 degrees. so i welded them up at about 50-55 degrees to clear the seat rails. bolted them to the floor and worked perfect!
in! after these pics i unbolted the shoulder harness and ran it threw the upper harness hole. i didnt like not feeling the strap on my shoulder.
best news is i got no dash lights or chimes with the stock buckles and electrical connections no longer existing. i was worried about that. i do have an airbag light from the missing/unpluged seat airbags.
also i have a good 1-2" of helmet clearance with the roof.
Weights:
Stock driver seat with air bag, motor, and rails : 49lbs
stock passenger seat with airbag and rails : 39 lbs
Invictus seat with homemade rails : 22 lbs
total weight savings : 44 lbs
painted
mounted
Weights:
#37
headed back to the track last weekend and got to try the latest round of mods. hood vent and seats.
hood vent:
the vent did work and helped a bit with cooling but not a huge difference. at when stopped you can defiantly see the heat pouring out of it. it took a tad longer to get to the uncomfortable water/oil temps. and allowed me to run at the top of that range a bit longer, but im guessing no more than a 5-10 degree difference in MAX temps before i did a cool down lap. conditions were identical at 85 ambient before and after. not sure if the cooling effects would be more pronounced on a 100* day. i do fell like it helped with the front end aero lift though. between the hood vent, and removing the air dam i really didnt feel the dancing i was getting before from the front end at top speed.
seats:
seats and mounts did great. super solid. the lower portion of the seat really held me in place very well. but as i suspected the narrower (than most race seats) shoulder width didnt hold my upper body as good as i would have liked in hard cornering. better than stock, but i still had to hang on pretty good, and my shoulders were sore as hell from it.
the place was more packed than id ever seen it. with lots of new cars. including this Superlite SL-C. must have been a new car shake down because he was off pace all weekend. i thought the nitto Envos were an odd choice for such a high end car. LS3 powered.
this guy also showed up. i think he was lost
Lap times:
with my previous issues with the lap timer, i moved my phone to a suction mount in the windshield. this seemed to solve the issues, i was getting consistent lap times/gps signal.
Saturday it said i was running fastest of 1:57s, and by sunday my tires were gone, this was there 4th and final weekend. but it said sunday i was running bests of 1:58s. i was really have to tip toe exits sunday. felt like it would spin at any time applying power.
however when i came home to look threw all the gopro footage i was only seeing bests of 1:59s. i think it may be time for an external gps sensor.
however there was one lap showing a 4 second difference in the start/finish times on the gopro so i ran it threw my editing program and did frame by frame start and finish and it said i ran a 1:56!
i couldnt believe it. thats 4 seconds faster than my best ever in the camaro.
i dont have it confirmed by gps timer, but at this point i have more faith in the footage than the timer. sadly the timer wasnt running during this session.
this is that lap.
and for the first time ever the vette lasted the entire weekend without breaking anything! super stoked about that. shes finally getting there. had a blast.
1 weekend of fun = 3 hours of rubber scrubbing....
hood vent:
seats:
Lap times:
this is that lap.
Chiselchst (05-18-2017),
#38
Sounds like you're having so much fun.
A full containment seat will definitely help with the upper body, but you may not like the lack of visibility on the street. There is one seat on the market that has removable halos, as well.
How are your front brakes looking? Pull the front calipers off the rotors and inspect the rubber dust boots. They will eventually melt if you are braking hard enough on an aggressive compound + sticky tires.
#39
i am!
yeah full containment is out. but in the future i may swap the seats out for something with allitle more wrap around shoulder support. especially now that i know i have the room for it.
thanks for the tip, ill look into that.
typically im not a threshold braker, but with that being said i did find myself several times that weekend getting the brake wiggle/front rear dance, enough to need quite a bit of steering correction, so maybe im braking harder than im giving credit for. but its rare.
#40
Glad to see that vent did a little bit of good after all the work put in. This may be something I give a shot down the road because of its functionality of course (and it looks bad ***).
You should log those times over a tracklaps! http://www.tracklaps.net/index.php
