Brake Fluid after flush with Wilwood 570 from ATE DOT 4
I ran my 2004 Z06 with Track Guys school at Heartland Park this past Saturday. Fantastic, well-run event and beautiful new surface.
I've owned this very well-cared for C5Z, extremely low mileage car for 2 years and autocrossed it heavily the past 2 seasons but never flushed the brake fluid. I've only run it at a handful of track days and generally taken it pretty easy on the brakes at those events.
Expecting heavy brake usage at Heartland Park I flushed the brake fluid. The previous owner told me the car had ATE DOT 4 hi-temp brake fluid. It was certainly blue. I flushed the system in the proper order with Wilwood 570. It took about 5 of the 12 oz cans.
During my inspection of the car yesterday after the track day I was surprised at what I found in the master cylinder (see attached pic). Can you experienced guys tell me what I am seeing here?
Was there buildup in the reservoir? Is there still buildup in the reservoir? Leaving the original fluid in there for the first 10+ years of its life will leave a brown/black layer of gunk sticking to the inner walls of the reservoir.
Our current working theory is there was water in the fluid that was hiding in the ABS unit (which can't be flushed without a computer controlled high dollar device). The ABS unit saw plenty of action on Saturday.
KCblues (04-18-2017)
Received 8,928 Likes
Sorry I'm confused by what you mean by reservoir? The master cylinder is clean and I haven't opened the ABS.
Bill
Thanks, I didnt' realize there were affordable Tech 2 units available. From what I've read there are plenty of bootleg and early poor quality units on the market, too. Damn, another research project I wasn't planning for!
I don't know about water in the BPMV but the fluid in your picture sure looks blue. That is evidence there was some of the old blue fluid in the system. However, it is hard to imagine the few drops that would have been caught behind some closed valves while you were flusing the fluid would turn the new fluid from amber to blue.
Bill
Bill
If it helps here was the descriptive information from the invoice. Wonder if they are out there under a different name now.. btw prepare to be disgusted when you realize GM's markup to dealers/tuners on these things:
S/N Product Name Price Qty. Subtotal
1 Best Quality Tech2 Diagnostic Scanner for GM(entire kit including 32mb card and candi)
Item No.SP23-C
Color/Style:GM-English
Size/Spec.:- 339.00 1 339.00
Items TotalS$339.00 DiscountS$20.34(6%) Shipping CostS$150.70
Total SumS$469.36
That blue dye gets everywhere. if even a few drops are still up under the reserviour cap, above the black rubber diaphragm it'll continue to turn the fluid blue every time you put the cap back on.
But my question is, did the fluid turn to blue crystals or is that just the picture quality?
Bish
something is in there. i would suck out all you can from the MC and then flush. you don't want to leave it so that means replace it
ate super blue typically mixes fine with dot3/4 other brands. i had an extra can of super blue i wanted to use as it was new but 4 years old. bled the 4runner which had OE toyota fluid in it. a year later the super blue looks fine even with some cross contamination of the original toyota dot 3
My old master was pretty nasty and I remember floating gunk occasionally. It has since been changed but for unrelated reason. AFAIK I've never had a fluid issue.
Clean it out best you can, bleed and don't worry about.
Check this out.. just noticed it after trying to figure out why my freshly flushed/bled (including ABS) SRF was changing colour after one track day.
Prior had ATE Blue in it... the stuff clings on everywhere, and it had a greasy consistency. Perhaps some kind of interaction with the rubber? I would bet amounts of this stuff hidden under the cap (the rubber seal/diaphragm part) is what caused your 'floating jelly' crap.
if the brakes worked fine, then you have nothing to worry about. Suck the reservoir dry with a baster/mity-vac and flush the heck out of it again before your next event. If you had serious moisture or contamination in you EBCM, you would have had brake problems.
