Front aero
Looks Great!
That's exactly what I've been talking about the last 2 years.
Can you provide details for the fender vents your purchased please.
Also, how did you attach those aluminum louvers to the fender? I don't see any bolts/rivets on top.
Thanks!
Thanks!
rkdc5z06 (06-03-2017)
Only thing I would change is to have the louvers hinged from the back side, and bent down and forward, just like my LG World Challenge hood.
AND have some center support to lock in the vanes, right now someone could just grab a vane, rock it back and forth, and break it off.
I chose "outies" because they help extract air from the wheel well as opposed to an "innie" which will help vent pressure from the wheel well, I wanted active extraction of all the air I could.
383 (06-07-2017)
FYI...Viper ACR has innies on front fenders....and if you want max air flow, they actually remove the vents and just have a giant open hole.
Supporting Vendor
That couldnt be further from the truth. The diffuser works well, even with poor aero in front of it. Does it work best with flat aero? Yep. Will it still work with a stock corvette floor? Yep.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
#38
To the OP: Great work! Looking forward to seeing more!
#39
Race cars are great for design inspiration. But you have to understand that often times they are working within a confined rule set. So you will see them do some funky things to remain legal. It may not always be the best setup efficiency wise because of the constraints.
In this case, however, the argument was that the vents themselves actually hinder airflow vs. just an open hole. The counter argument was that the Corvette race team uses them, so that's likely not the case.
I'm not aware of any rule restricting vents vs. open holes.
Reguardless, the vents help to laminarize the airflow coming out of the fender as it joins the air coming over the car. If they weren't there, you'd get a bit of turbulence as the two air streams mixed together.
#40
Supporting Vendor
Jeremy is right, that you have to be careful when you look at the GT cars. However, you also have to look at other cars, like the LMP cars when discussing this stuff.
In this case, you must not be able to see the wheel and tire from above. Hence the louvers.
