Data logging & lap timing with brake pressure and steering angle?
Im wanting to get a lap timing and data logging solution for track days in my C6z, however I havent been able to identify a solid solution which provides brake pressure and steering angle data. It appears as if the AiM Solo DL might capture steering angle, but I haven't been able to definitively confirm that is the case. Even still, it appears that brake pressure data is unavailable.
Ive been using HPTs stand alone logging so far, but would prefer an integrated/all-in-one type solution that will automatically start and stop as well.
What are y'all using to capture this sort of data?
Supporting Vendor
http://www.aim-sportline.com/downloa...ay_102_eng.pdf
Keep on selling, brother forum vendor. I ain't buying.
Supporting Vendor
Sorry I misspoke. Thanks for setting me straight but I'm not selling anything and the attitude is unnecessary.
In that case if the AIM Solo DL won't spit that info out for you than I guess you'll need to step up to something that can accept signals from the ECU or stand alone sensors. It was not hard to wire that info in to my particular dash, but admittedly I had someone who's way better than I with that stuff take care of it for me.
No brake pressure for the C6 on the Aim Solo DL and the steering angle channel is known not to work if you searched the forum before posting that.
I note a C6 in your avatar; assuming it's your car, what are you using?
This is precisely why I asked; I've been searching but haven't found any real info on what folks are using. It seems like folks have either gone to a full-on race dash (fine in a race car, not so much otherwise), or they don't log data at all.
A few years ago I submitted a help ticket to Aim for the steering channel because it logs noise. To resolve the problem, they had me send them some log files. Their conclusion was that a Euro spec C6 has a different ECU than a US spec model so that's why it doesn't work for us. I don't know if that's true or not, but they considered the issue resolved and closed the help ticket.
I too would love to hear if and how other people log brake pressure and steering angle on the C6 with the same constraints you mentioned in your post.
The AIM technical,support team in California is very knowledgeable and helpful. I would recommend giving them a call. Also the Rennlist forum has a specific section with AIM experts who are extremely helpful. And they don't care that you are asking about non Porsche applications. Both of these sources have been very helpful in getting the AIM system (piesta dash with smartycam HDGP) set up in my Radical. Obviously the set up for a Radical is different than a Vette, but my car is set up with brake pressure sensors for the front and back brakes and I have a linear sensor for the steering angle. The brake and throttle sensors are very helpful, but I really don't use the steering angle for anything.
Charley
Charley
Charley
Charley
https://rennlist.com/forums/data-acq...ng-and-de-233/
Yes. You will get quick knowledgeable responses. You can also contact AIM technical support in California at (951)674-9090. They are very helpful.
Charley
Charley
Poor-sha (06-09-2017)
Side note: you CAN log wheel speed sensors which is infinitely helpful to identify when the sensor is dropping out and needs replacement and exactly which sensor is going out. I know those show up as DTC's but if you have it setup in your AIM and your downloading data anyway for review, its a quick check at the same time to find the errant sensor quickly.
They can get damaged with contact and when you break an axle, sadly I've had to replace hubs for both reasons.
And I was able to log an Ice Mode braking event that shows exactly what the car does.
JerryTX (06-13-2017)
At the moment im looking into building a PnP harness for the brake pressure and steering angle sensors to plumb them into HPT. Given that the brake pressure trace is more about smoothness than actual PSI, I figure that should work just fine. Not sure what Ill have to do with the steering sensor just yet. Of course, for all i know at this point it wont work anyway because the added load on the sensor circuit could flip out the EBCM, etc.
Its unfortunate there isnt a ready-built solution at this point!
Harry's LapTime & OBDLink MX
Looking to capture similar data with Harry's Lap Timer and
OBDLink MX. What are the PIDs for steering angle and brake pressure on 2016 Stingray?
