Corvette Z06 sue GM With Class-Action Lawsuit Because The Car Is So Bad On Track
#161
Received 8,928 Likes
Bill
#162
Just my opinion but at track speeds running your heater will not stop your car from overheating. If your car is going to overheat on the track, it is going to overheat regardless if the heater is used or not. The amount of btu's removed from the heater core with the fan on high is a minuscule percentage of what a 650 hp is producing. Also, there is no free ride as when you run the heater on high the fan draws amps and the alternator has to supply those amps which adds load to the engine and slightly offsets the btu advantage you're trying get using your heater. Plus, the air flow moved by the fan and duct restriction is very minimal compared to what a radiator in 80 mph air flow can do.
At idle or stuck in stop and go driving, the heater might help....but on the track with the engine maxed out, no way.
#163
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
#164
Running the heater on high doesn't mean you run the fan on high. All you want is air flow through the heater without it being shunted somewhere else by the HVAC. Set the fan speed on low, set temp on high. At speeds between 90 Plus mph there will be sufficient air flow through the heater. The inside of the car will get very hot but the slightly increased cooling capacity permits the driver to see a reduction in engine temps.
Bill
rb185afm (02-25-2018)
#168
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Problem has been solved
Guys, I know you are trying to get past the overheating without modifying the car but that is not going to happen.
The law suit should ask GM to supply you with a system like our LG dual Intercooler system that they emulated not the new ZR1, Gee, who would have thought?
this is the car that we ran over and over at professional race speeds with no issues, OUR WATER TEMP NEVER GOT OVER 194F in the entire event on track winning the event. NOW this car is heading to Nurburgring to set our best time.
AND our engine has a cam and headers with 800 Flywheel HP..
Have your lawyers call me and I can explain the short comings of this car that only needs our aftermarket cooling package.
Lou Gigliotti
LG Motorsports
Don't waste your time and money going to track days and only doing a few laps.
Lou Gigliotti
LG Motorsports
#170
How does the HVAC system work? It's not coolant bypasses the heater core when the heater isn't on. Isn't the difference between "cold" and "hot" just how open the baffles from the "hot" side are in the HVAC ducting? Wouldn't coolant be going through the heater core no matter what?
I'm sure it helps, but it's a nominal amount. As a former powertrain development engineer, I can tell you the Z06 definitely has a major design flaw when it comes to powertrain cooling.
With that said, as an attorney, I highly doubt the class gets certified. The damages are just too inconsistent. Some people track their cars, some dont. Some people knew about the problem and bought it anyway, some didn't. It would be a real fumble by GM's lawyers if they couldn't break up the class and force everyone to sue individually (which no one would).
#171
2018 Corvette Z06 or ZR1
I am getting the itch to get a new 2018 Z06 or ZR1 Corvette. My only concern is that class action lawsuit that was filed about a year ago claiming that the cars were not track ready for the earlier 2015-2017 vettes. Has anything changed with the new vettes and has it been proven to be a resolved overheating issue thus eliminating 'limp mode"?
#172
#173
So is this documented anywhere yet? I live in Texas and we are at 102 today. I want to get my hands on as much 'proof' as I can before I buy....just like those plaintiffs said....why by a bad *** track rod if you cant track rod it?
#175
how do i join the class action suit on Z06
#176
I saw them running out there if that helps though.
#177
Have you had your A8 over heat on track? Very few M7s over heat (I personally don't know of any that have) and M7s are well represented at track days where they are pretty much the Ultimate Track Car.
Unless they have some way of keeping readily available public data showing how well these cars run out of the court room the action is doomed. I probably have 30 videos posted on YouTube showing how well my car does and there are plenty of other people posting them as well.
Bill
Bill
#178
Bill
Bill
If it's warm out (85+) and especially if it's not a 17 and up, it's pretty prone to overheating if driven hard. Manual 18's were overheating in 90 degree air when I was at Spring Mountain, and it wasn't uncommon. The drivers were instructed to short shift.
