Official Essex Designed AP Racing Brake Wheel Fitment and Picture Thread!
#41
Supporting Vendor
Unfortunately not. You'd have to check our templates...or rather have Forgestar do so for you...links below. If they aren't willing to help you out and do that, you should be shopping for a different brand of wheels!
https://www.essexparts.com/storage/w...template_2.pdf
https://www.essexparts.com/storage/w...l_template.pdf
#45
Supporting Vendor
Essex has formed the "Essex Designed AP Racing Brake Kit Owners Club" on Facebook.
The group will be a digital extension of what we've seen among our customers out at the track, which is like-minded car nuts parking next to each other and sharing stories, ideas, photos, setup tips, pad advice, discussing future track events, etc. Not only will group members be able to interact with other Essex brake kit owners, Essex will be offering a number of exclusive perks and opportunities that will only be available to group members. How do giveaways, discounts on spares, contests, and even unique schwag sound?
The only prerequisite to join this group is that you need to own an Essex Designed AP Racing Competition Brake Kit. To keep things fair for other members, we will ask you a couple of questions to verify kit ownership prior to approval.
Click this link to join:Meet Other Essex Brake Kit Owners Now
Thank you all very much for your continued support!
Nick__S (12-07-2018)
#46
Has anyone been able to confirm if any of the C5 Z06 repo wheels will fit the kits that the oem speedlines fit?
Im looking to have a set of wheels for tooling around on the street that wont break the bank but wasnt sure if there were any clearance/spacing differences between oem and repos.
#47
St. Jude Donor '15
Year, Model, Trim: 2012 LS3 Base Coupe 457RWHP
Front BBK: Front CP8350/325mm Sprint Kit
Front Wheel: TSW 17x9 Nurburgring ET50 for track, TSW 18x9 Interlagos ET50 for daily. Neither with spacers.
Feedback: After install, the front OEM wheels with +56 offset would no longer fit, but thankfully I had my new track wheels available with +50 that fit just fine.Have had them for less than a month, but have done two track days after install. The new front kit, along with wider tires, have dropped my lap times at MSR Cresson 1.7CCW by a little more than 3 seconds! The new confidence I have with the brakes is a big part of that. I can hammer on the brakes now and I know they will work and feel the same each time. I have the Ferodo DS1.11 race pads and the pad use was not really noticeable IMO, but again just two track days. When swapping to my street pads, I had to really bang those pads out of there because they were in so tight in the caliper..lots of pad left. I anticipate that the pads will be lasting at least two seasons for me. I used the Carbotech 1521 as my street pads, part# CTFRP3116-1521 and it was a perfect fit. Make sure and get the D50 Center Arc. 20mm thickness from Carbotech.
JRitt@essex (02-04-2019)
#48
Supporting Vendor
BigMonkey73 (02-04-2019)
#49
Year, model, trim: 2002 Z06
Front BBK: Front CP9660/355mm Radi-CAL, Part #: 13.01.10024
Front Wheel (track): Enkei NT03+M 18X10.5 +64mm offset, no spacer
Front Wheel (street): TSW Interlogos 19X10.5 + 65mm, no spacer
Rear BBK: Stock C6 Z51/330mm
Rear Wheel (track): Enkei NT03+M 18X10.5 +64mm offset, no spacer
Reat Wheel (street): TSW Interlogos 19X10.5 + 65mm, no spacer
Feedback: Just installed and driven only a few miles. Going to VIR this weekend and will update post.
The following 2 users liked this post by kflee:
C5 Hardtop (05-07-2021),
JRitt@essex (02-25-2019)
#50
Supporting Vendor
Those wheels look familiar!
Thank you sir for the data points! I'll get them added to our listings. Car looks great...I miss my yellow C5Z.
#51
#52
Hello Jeff
I changed my brake CP9668 / 372x34
from the C7 Z06 to the C7 Stingray
I bought TSW Nürburgring 18 inches
Front 18x9 / 50 Rear 18x10.5
Grind 10mm spacers and a little on your brake caliper and it fits
I'll give you some pictures tomorrow
Cölestin
Cölestin
JRitt@essex (02-26-2019)
#53
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Curious if most using the Radi-Cal caliper are using the bolts through the bridge or the quick change spring/clips. I had been running the Anti-rattle clips and bolts until I removed but recently put the quick change spring clips in for fast pad changes. Not sure why I didn't do that the first time as it is so much easier to swap pads! I expect there could be some noise but wonder if it will even be noticeable.
#54
Supporting Vendor
#55
#58
#59
Feedback: Just finished first event with the front bake kit. Chin at VIR. First day was North Course (my first time), second day was Full Course. I shaved 2 full seconds off my personal best on full course! This was the only change since last time on VIR Full, so I attribute most of this to the brakes. They felt solid lap after lap giving me confidence to go a little deeper into each braking zone.
thanks,
Kirk
thanks,
Kirk
daleong (03-04-2019)
