Hoosier R7 life span?
I have an '09 Z06 with OE size R7's. They have about a dozen 20-25 min. run sessions on them. I know they use heat cycles to judge their usefulness, but wondering about how much longer they will survive. The tread wear holes still look ok.
Also.....Best way to remove the welded on slabs of rubber that have bonded themselves to the slicks?
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Into the third season with R7's. They still grip sufficiently but nothing like the first day. Mine are long in the tooth and I inspect every session for no more rubber. As far as built up rubber boogers, just put the tire on the rear and give it a good hard session. It should clear up but you may need to clean out the inner wheel well liner.
EdsC6Z06 (07-10-2017)
sounds way better than the cup2 michelin tires on a c7 z07
Received 8,928 Likes
I have 28 sessions on a set of R7s that I purchased new last July. The tread depth holes are still visible but I don't know how much is left on the edges. I swap the wheels from one side of the car to the other every event and I have flipped the tires on the rims twice to try and even out edge wear. The last time I used them was at the NCM VIR event and they were getting a little greasy during the last few sessions.
Bill
Bill
This weekend I put sessions 24, 25, 26, and 27 on my "scrub" R7s (so add about 2 to the above). Running 315x18 front and 335x18 rear on a modified C5 (ST2). They started to fall off hard during my 24th session (about 2 second difference between the beginning of session 24 and end of session 27). But they were pretty consistent up to that point (i.e., sessions 3- 23 were pretty much the same, maybe 0.5 to 1 second falloff on a 80 second track across all the sessions).
I used to believe this worked, but my last run at Pocono was almost traffic free and I ran as close to 10/10ths as I ever get to do and the tires were still loaded. I like the heat gun video. Gonna try to scrub some of the crap off before the Glen. Thanks for all the replies. Good info!
I would get about 8-10 sessions on a set of R7's and 4-5 sessions on set of A7's, but this is not on a Corvette but rather a SCCA A Sedan car.
To get the goobers and rocks off the tires, get a curry comb and scrape off the tires immediately after each session while the rubber is still warm. This will give you "clean" rubber for the following sessions. I would follow with a gloved or towel rub down of each tire to get any remaining material off.
No competition, but I like to run as hard as possible. Hate to replace them early and only have one two day event left scheduled for this season. I think I'll probably clean up some of the track snot attached to them and hope they hang in for a few more heat cycles! Thanks for all the good feedback.
rb185afm (07-19-2017)
