Whoa. Very nice. How many hours did you put into this project? What power plant did you go with?
What this is is a bucket list car. Built lots of cars and modified plenty.
Did enough sheet metal fab to kinda get the hang of it. Said some day..............well i made myself take this on. The design is all the things i liked from different cars of the era. 5 years and lots of frustration and learning here it is. trimmed the c3 down to 2600lbs with the alloy body work. 50/50 weight dist. 383/415hp tremec 5spd. stops,goes and corners. The tires are the limits. I just cruise in it. Thanks for the kind words, Ray
Awesome style, same for your talent. IF you have that kind of talent you should do that to a c6z. Then the entire car is aluminum. Maybe I'll donate mine to the cause
I have been thinking about basterdizing a late car. I'm scared of the electronics and air bags etc.............Ray
Thanks, I brought this c2 home and it was to go under the sawzall like the c3. It's in 3 chunks and has a restored frame under it and the nom 327/4spd. I started to save it............ some day's maybe not. Ray
Today I did what I should have done when the frame was out. The car was built with the 4spd and I then did a 5 spd. I put it in from the top...........Had to fab a aluminum tunnel that was removable and it went in through the passenger door. Now that it's together and have put 2k miles on it i decided to do the removable cross member thingy.
Hindsight . Ray
