can a splitter help cooling? (front breather C6)
My car now cruises at 187. It used to cruise at 194 so yes, deshrouding a radiator DOES improve cooling but I can't say by how much when you induce the heat from tracking the car. My fan is still controlled by the PCM but there is no low/high, it kicks on around 200.
Fellow TX C6 track-rat here.
I did the DeWitts stand-alone radiator (trans and diff have their own coolers), dual spal fans, 160* thermostat. I then focused on sealing off the front part before the radiator using the Katech undertray w/brake ducts ( https://www.corvetteforum.com/forums...pre-order.html ) and a small rectangle of sheet aluminum to close the little leaf-dropdown hole right below the radiator. I realize there may be a bit more that could be done to further seal the inlet portion, but for now, it does the job for me.
Behind the radiator, I have the LG W.C. hood for ventilation, as well as removed the plastic inserts behind the fenders to increase airflow out of the bay (and hopefully create a suction effect through the radiator that helps increase airflow).
I have actually thought about a way to further increase airflow into the radiator by modifying the front bumper to resemble something like a wedge shape on the bottom lip area, similar to this if my temps ever start to get TOO out of control:
That's on the extreme end, of course.
In between sessions, I am running a snail-style fan into the front grill w/the hood off to help get air blowing across the radiator and heat blowing out.
http://www.homedepot.com/p/Lasko-Pro...4905/202185788
When are you overheating?
option #2 is ive looked at one of the Duraflex "stingray/C7" style from bumpers for the C6, for the sole reason that that appear to have a much larger grill opening than a stock C6 bumper
even though i bought the dewitts rad, ive often wondered about a forward tilt rad. ive seen it done several times on C5s, but ive never see it done on a C6. i assume you must go to a shorter rad to get it to fit?
more info on this "custom water pump". where can i get one, what was done to make it "custom" and cost?
ive never heard anyone else mention this mod.
I have an LS3 water pump on my car (supposedly better than the LS2 one) but still have the hoses run to the heater core. I figured if nothing else it acted as another heat exchanger removing heat from the water as it runs through the system.
Just as important as radiators and and pumps is having a smooth airflow in on a front breather, a friend has a very well sorted C5 ST1 car that had trouble staying cool, after chasing different and bigger radiators, it turned out that a sharp upward bend was causing a vortex literally blocking airflow the the top half. Smoothed it out cooling troubles gone!
Premium Supporting Vendor
What hood are you using. What hood vents do you have on your car? Do you have a picture we could look at?
Give us a call at LG Motorsports. 972.429.1963 ask for Lou.
Thanks,
Dane
LG Motorsports
Thanks,
Dane
LG Motorsports
currently running the SS extractor(no drip tray). and going to be adding the mustang vents on the sides to closer replicate the WC hoods and add more opening area.
do you have any data on if a splitter does direct more air into the grill opening?
would be a flat race style splitter, not a ZR1 style.
I've never seen that Duraflex C7 front bumper on a C6 before! It looks so goofy!!! Maybe I'm used to the C6 looks.
Anyway, I'm glad to have met someone as crazy as I am who would take a sawzall to my car to alter/modify to get things to work.
I don't see why chopping off the lower part of the bumper to increase the opening size wouldn't work. I mean, when is "too much airflow" a bad thing? I would, however use that as a last resort. I would work on sealing off all air-escapes in front of the radiator (as Z06801 stated, I also hate that upward bend, hence my attempt at creating suction on the back side of the radiator to help counter-act that), and then work on venting behind the radiator to pull air through and let it escape.
Something like this?
Front splitter increases air speed below bringing the car toward the ground, with a slight amount of rake then it could channel more air into the radiator. I don't see it being a measurable amount. Our WC hoods utilize an aerodynamic feature to help pull air out of the vented area's. If you'd like to send the car to us we'll do the forward mounted radiator for you.
#33
https://nasaspeed.news/tech/engine/r...ic-principles/
While I was no longer having cooling issues I do believe I helped the extractor pull more air out and increase downforce.
#34
Originally Posted by Hi Volts Z06
This is actually a very important fact. I redesigned my intake ducting after reading this article which I'm pretty sure is about your friend
#35
my c6 z06 was originally a florida track day car, now a nasa st2. the previous owner installed twin oil coolers in place of the fog lights. even though its oil cooling, I'm convinced it is big factor why my car runs cool.
#38
