Post alignment, tire rubbing in wheel well
Old 10-30-2017, 02:11 PM
BigMonkey73
BigMonkey73's Avatar
St. Jude Donor '15
Default Post alignment, tire rubbing in wheel well
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
"Performance Street - Track Use with Street Tires" are the alignment settings I had a local shop do for me about 6 weeks ago.
Just had an HPDE event Saturday..no issues.
My only complaint is that the passenger front tire rubs on the plastic in the wheel well when I'm doing a sharp turn to the left.
This is only during street use..didn't notice it on track since I didn't have any turns that required that much sharpness I suppose.
This is for a 2012 base model. Should I try different settings? Or what else would you suggest, if anything, to get rid of the rubbing?
Old 10-30-2017, 04:18 PM
Scooter70
Scooter70's Avatar
Don't turn the wheel all the way.
Seriously, we all deal with it when running wide tires and "performance" alignments.
BigMonkey73 (10-30-2017)
Old 10-30-2017, 04:26 PM
BigMonkey73
St. Jude Donor '15
Yep..as long as it's OK on the track..I don't mind.
Was just wondering if there was a fix / workaround that I was missing.
Thanks man!
Old 10-30-2017, 05:04 PM
synner
synner's Avatar
Only "fixes" are less camber, narrower tire or changing wheel offset.
Old 10-30-2017, 09:45 PM
Dropspeed
Dropspeed's Avatar
Yep. 315 Tire, -2.8 Camber.
BigMonkey73 (10-31-2017)
To Post alignment, tire rubbing in wheel well
Quick Reply: Post alignment, tire rubbing in wheel well
