New race car intro-Nasa st2-09 c6 z06
The following 4 users liked this post by mp4659:
#43
So right off the bat, caging the aluminum chassis adds a pretty significant expense as it is a lot more work. Then there is the debate of what is the correct way to mount the cage to the chassis. Welding aluminum mount plates to the frame, thru-bolting, rivnuts etc. Welding alum. mount plates to the frame provides the most direct attachment to chassis but to some extent you risk annealing the aluminum frame. Thru-bolting presents some challenges, mostly in how and where you are thru-bolting and accessing sandwich plates etc. I know there are some very strong rivnuts out there, but I wasn't comfortable (personally) trusting my cage attachment to them but I have seen it done. The other factor to consider....repairablilty. It's racing, crashing happens, as I've painfully already learned. I put the car in the tire wall my first time out with car after I hit some water that puddled off curbing. Luckily, other then a bent rear control arm the damage was strictly cosmetic, and yes I did have the car on a frame rack to check for straightness. (Phew!). That being said, a steel chassis is much easier to repair.
#44
Supporting Vendor
If you're not rolling quite so hard, the Grandsport should should save you considerable coin if turning it into a race car. If I was starting over it would be a C6 GS.
#45
The advantage for me was I already owned this z06 . If i knew I was going to build a race car originally, I would have started with a c6 grand sport as well. An ls3 could easily make the power my ls7 is making for this class and you wouldn’t have to spend money having the heads “fixed”.
