C5 z06. Trans cooler install. Temp sensor in drain rather than return?
Hi. Just finishing my trans cooler install. Similar to the DRM kit.
As standard the temp sensor goes in the fill hole. This becomes the return from the cooler typically with a t piece fitting to accommodate temp sensor and return oil line.
In this configuration the sensor is no longer in the gearbox and it would be reading the return oil temp not bulk box temp.
Any reason not to move it to drain / cooler feed location? Now your measuring bulk box temp. Only issue I can see is having the bulky t-piece in a more vunerable location on bottom of box.
Thoughts? Thanks.
Thoughts? Thanks.
I think its important to know how hot the oil is getting.
I would mount mine somewhere between exiting the diff and before entering the cooler, depending on ease of accessibility, wiring, etc.
I put a T on the inlet to the pump and put the temp sensor there. This way you're getting exit temps but in a secure protected location behind the wheel well. Also makes the wiring easy as you can run the temp wires with the power wires in one loom.
I did something similar except my T fitting is at the fill hole. We used a nipple out of the trans to the T and then installed the temp sensor in one end and the output to the cooler pump in the other. This way you are getting almost the exact location and can reuse factory plug without extending wiring.
