AMT Motorsports monoball sphericals C6Z06
Max G’s
Just finished installing a complete set of monoball sphericals for the upper and lower A arms front and rear. When I initially ordered these from AMT I had read some post of other manufacturers having fitment issues so I had a little concern that I might have same issue.
As I unpacked the a arms I could see the quality of the parts used making the sphericals. As I started installing the tolerances were very tight, which is what you want, and the lower and upper arms fit were perfect. It couldn't get any better. I couldn't believe how good they fit. If you are considering sphericals, you cannot go wrong with AMT Motorsports.
Olitho (03-11-2018)
Supporting Vendor
Thanks for the kind words. We are getting ready to shoot a video of the whole manufacturing and install process. There is more that goes into making these things perfect than you might think. We are also going to be outfitting the Grassroots Motorsports project C5 with a set. Will be headed down to do their GRM Live show on April 4th, where we will be installing the control arms and talking about the product, should anyone be interested. Please let me know if I can be of service!
https://amtmotorsport.com/products/corvette-monoball-control-arm-bushings
Damn....I was thinking powder coating them clear but the colored versions look a lot better than I thought they would. Nice work!
I'm not sure anything would contrast well with Millenium yellow other than black. Black would look definitely look like a factory skunk works race project....all function, no frills.
Supporting Vendor
If I was going to do anything it would also be black. Then again mine is a racecar so I don't really care what my control arms look like.
In another news I just bought a complete set of C7 control arms to work up a monoball kit for all C7s. If anyone is interested let me know!
I was also very pleased with the quality of parts and services from AMT. Even more pleased about overall improvement in handling. Literally zero compliance which intimately connects you to the tires and racing surface, making for an extremely predictable platform.
Mark@AMT Motorsport (03-15-2018)
Supporting Vendor
Thanks Chad! It's that predictability that I think makes the car so much easier to drive at the limit with sphericals, which will translate to lower lap times. When the car starts to oversteer or understeer you feel it immediately and it's just an easy correction to get back in shape, where as with rubber you have to wait for the bushings to compress before you feel anything and then your correction has to be that much bigger. It's really just like a big go kart when you go to sphericals. Best suspension mod I've done to my car for sure.
Sorry to thread jack Mark. Are those the van steel JRi shock package you have or are those custom mounts? I'm looking at going coil over with my JRi's but to change em over it'd be almost as expensive as just buying complete new set.
