The "Will This Seat Fit In My Car?" thread
Old 09-16-2018, 03:33 PM
  #41
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
Generation, Year, and Model: C5, 2000, Coupe
Driver Seat: Sparco Evo
Driver Mount: Home made
Driver Sub Belt: N/A
Passenger Seat: Stock
Passenger Mount: Stock
Passenger Sub Belt: Stock
Harness Bar or Cage: N/A
Interior?: Full
Carpet?: Yes
Stock Belts in car?: Yes
Driver: 6', 170 lbs, 32 waist
Notes/Pics: Positioned the seat for about 3/8" clearance to the door. Unwound the stock lower belt from the retractor and fed the belt through the seat.
Rx7Rob is offline
Old 10-14-2018, 10:57 AM
  #42
IBAUCLAPlaya
CF Member
Generation, Year, and Model: C6 Z06, 2009
Driver Seat: Racetech RT4009W
Driver Mount: Brey Krause BR9144 Seat Mount with Integrated sub bar, BR9061 Side mount bracket, Sparco SP493 sliders
Interior?: Full
Carpet?: Yes
Driver: 6', 180 lbs, 34 waist
Notes/Pics: Seat fits, however with this setup it sits much higher than factory seat. I have to remove padding to fit in the car with a helmet and feel like even without the padding, it still sits higher than factory seat. Also slider range is limited, at the further point back there is still a few inches further it could go which would be nice.
Can anyone tell me if there is another mount & slider setup that would significantly lower the seat and also set it further back to allow for more leg room?
IBAUCLAPlaya is offline
Old 10-19-2018, 04:14 PM
  #43
Fast Eddie I
CF Member
Fast Eddie I's Avatar
Corbeau FX1 in a C6Z? None of the posts mention a Corbeau install. The FX1 is sized between the Fx1 Pro and the wide version. My C6Z has a full interior; no stripping desired. Any insight will be appreciated.
Fast Eddie I is offline
Old 10-25-2018, 10:45 PM
  #44
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Timely thread. About to install an Ultrashield on AMT mounts in a C7.
Tool Hoarder is offline
Old 11-06-2018, 08:36 PM
  #45
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Has anyone put an OMP HTE-R XL in a C7? Also, what is the total weight loss going from stock comp seats to the HTE-R?
Poor-sha is offline
Old 11-06-2018, 09:07 PM
  #46
badhabit_wb
CF Senior Member
Sean this might help.https://www.corvetteforum.com/forums...n-the-c7z.html. i love the 4119-w Racetech and they are really close to the same size. It's a really tight fit.
badhabit_wb is offline
The Following User Says Thank You to badhabit_wb For This Useful Post:
Poor-sha (11-07-2018)
Old 11-06-2018, 09:59 PM
  #47
fleming23
CF Senior Member
fleming23's Avatar
Personally, I think the "A" measurement of 580mm would make it very difficult to not modify the door panel. It is close with an HTE-R 400, but at less than an inch in total additional width, or 1/2" per side, I suppose it could work.
Any particular reason you don't want to do the 400? I'm not a small guy by any stretch, and I fit the seat just fine. I
fleming23 is offline
Old 11-07-2018, 07:24 AM
  #48
Poor-sha
Track Rat
Poor-sha's Avatar
I'll see if OG Racing has one to sit in but as I recall you had to cut your to get it to fit and I'm a good bit wider than you are.
OG only had an HTE-R and an HTE-R XL sitting out to try. I honestly wasn't sure if they still made the 400 until I got home. I'll try that out.
Does anyone have any solid data on the weight of the 3LZ/ZR comp seats compared to the HTE-R + rails? I'm really not going to mess with it unless there is at least 50 lbs to be saved total by replacing both seats.
Poor-sha is offline
Old 11-07-2018, 08:12 AM
  #49
fleming23
CF Senior Member
fleming23's Avatar
I can attempt to scale mine this weekend. I'll be puling the HTE 400 to swap the oem 2LZ seat back in for street use over the winter.
The Following User Says Thank You to fleming23 For This Useful Post:
Old 11-07-2018, 10:19 AM
  #50
badhabit_wb
CF Senior Member
Comp seats weigh 56 lbs, or at least the passenger side does, according to this thread https://www.corvetteforum.com/forums...ld-thread.html If I remember correctly my drivers side seat felt heavier than the passenger side did. The racetech seat weighs 20 lbs but I'm not sure what the AMT mount weighs.
Old 11-07-2018, 10:34 AM
  #51
Tool Hoarder
CF Senior Member
Ordered a custom-sized 16" Ultrashield Pro Roadrace seat (5-6 week lead time) and have AMT's mounts. Shoulder width ended up at 22" and looks like it will just fit in the C7 with the seat down low. Will post up my experiences fitting it. Have to install the BK bar and get a seat back brace.
Old 11-07-2018, 01:23 PM
  #52
Werks
CF Senior Member
Hey Sean, it's been a while! Can't help you with C7 info but I put a HTE-R XL in the C6Z that Katech built for me and did not have any fitment issues. I believe the C7 may be a little narrower so it might be close in once of those. It's an awesome and very comfortable seat so if you can get one it I think you are going to love it!
Werks is online now
The Following User Says Thank You to Werks For This Useful Post:
Old 11-24-2018, 02:09 PM
  #53
moose.b3
CF Senior Member
moose.b3's Avatar
This should be a sticky
moose.b3 is online now
Old 11-27-2018, 08:04 PM
  #54
smitty2919
CF Senior Member
2003 Z06
Full interior
Corbeau Forza seat
Corbeau C5 seat adapter and Corbeau dual locking slider
The shoulder support BARELY touches the door panel when the door is closed. I could slide a piece of paper b/w them so it's not forcing against the door.
Only needed to oval out the seat bracket holes since I assume my seat studs were slightly off during the vehicle assembly. I'm 6ft and I did not see a need to do any shimming or get stud extenders. I MIGHT add some washers under the front seat feet to slightly recline the seat.
smitty2919 is offline
The Following User Says Thank You to smitty2919 For This Useful Post:
moose.b3 (11-27-2018)
Old 11-27-2018, 10:42 PM
  #55
Tool Hoarder
CF Senior Member
Custom Ultrashield Pro Roadrace: 16" base, 22" shoulders, 2" taller. Just test fitting. Will post up when actually done on brackets.
Old 11-27-2018, 11:51 PM
  #56
[email protected] Motorsport
Supporting Vendor
Mark@AMT Motorsport's Avatar
Just updated the thread so all the links at the top jump to all the correct posts. Thanks for playing guys I know this thread has helped a lot of people!
Mark@AMT Motorsport is offline
Old 11-28-2018, 08:35 AM
  #57
badhabit_wb
CF Senior Member
Glad you started it.
Old 12-08-2018, 10:01 PM
  #58
ttx350z
CF Senior Member
ttx350z's Avatar
Generation, Year, and Model: 2009 C6 Z06 2LZ
Driver Seat: OMP Champ-R
Driver Mount: Planted base/Planted seat bracket/OMP Dual locking slider
Driver Sub Belt: Planted base
Harness Bar or Cage: Waiting for Sharkbar to be delivered
Harness: Schroth Profi 3x2 pull up
Interior?: Full Interior
Carpet?: Yes
Driver: 5'7", 150 lbs, 32" waist
Notes: Got the seats and harness brand new for $650 shipped. Killer deal considering the seat retails for $650 and the harness another $400 if bought stateside.
Next to stock seat
Sub belt mounted to seat base
Seat, base, slider, bracket, sub belt
All done minus shoulder harness. Still waiting for delivery.
ttx350z is offline
Old 12-10-2018, 08:42 PM
  #59
DudeWithAVette
Junior Member
Probably a dumb question but no better place to ask it.
I'm installing a driver side seat this off season using the AMT ultra low mount and a Brey Krause harness bar. Does it matter which stud extenders are used (marad vs vetteworks)? Is two enough for just the rear or is it ideal to use four to keep the mount level?
DudeWithAVette is offline
Old 12-10-2018, 09:35 PM
  #60
badhabit_wb
CF Senior Member
AMT sends the extenders with it's mount if you're talking about the seat mount. They also sell the bar to hook the submarine harness up below the seat. Hopefully that's what you're asking.
Quick Reply: The "Will This Seat Fit In My Car?" thread
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
