rollbars..
Old Apr 3, 2018 | 04:48 AM
Ahrmike's Avatar
Ahrmike
Default rollbars..
After seeing a few too many flipped C6s that end up utterly squashed, I'm on the hunt for a bolt-in C6 roll bar that wont require too much modification on the car. I'm not looking for tech-passing bars that will let me run 9s. I'm looking for a little insurance in case the worst case scenario occurs. I want a 2 point hoop or 4 point bar at the most. I figure a 2 pt going to the seat mounts (if it covers the seat it should save my head, i presume..) or a 4 pt going from the seat to the rear frame will be more than enough as a CYA...
Where would be the best place to source some decent priced bars/hoops?
Old Apr 3, 2018 | 08:58 AM
davidfarmer's Avatar
davidfarmer
I don’t know Of anything premade that would be stronger than the OEM steel hoop.
Old Apr 3, 2018 | 09:20 AM
Quickshift_C5's Avatar
Quickshift_C5
Where are you seeing all these Corvettes with the rear hoop squashed?
Are you sure any you came across weren't convertibles?
Old Apr 3, 2018 | 09:37 AM
C6_Racer_X's Avatar
C6_Racer_X
Unless the thing is completely stopped and someone tips it over, a 2 point bar is totally useless.
Is yours a convertible? Or a coupe? The convertibles could use some extra protection. Autopower has a non-racing 4 point "street/sport bar." Technically it's a weld in piece, but it's possible to weld on some pads and us a bolt in mounting, if the design of the car allows it. I haven't looked that closely at the C6 to see how feasible a bolt in mount would be. There are a few other choices that come up in a search for "C6 Corvette Roll Bar." Some look good and others look more decorative than functional, and might be more dangerous.
One other thing, with a roll bar or roll cage, the car is pretty much "helmets only" after that. The odds of a severe head injury in a collision when your head smacks the bar are much higher than having a head injury without the bar present.
Old Apr 3, 2018 | 09:42 AM
Quickshift_C5
Absolutely the case for a true full cage, but not a behind the seat 4pt roll bar. How in the world would you hit that?
Old Apr 3, 2018 | 11:14 AM
C6_Racer_X's Avatar
C6_Racer_X
You've never been in a collision, have you? Things flex and stretch in ways you wouldn't expect. I was rear-ended in a 1990 Miata once, and my head hit (and bent) the soft top hoop behind the top of the seat. It looked impossible to me, but I had the bruises on my head, and the bent hoop to prove it happened. If I had had any kind of roll bar in that car, I would have had much worse injuries to my head and neck.
Old Apr 3, 2018 | 12:18 PM
Quickshift_C5
I've been in several collisions that totaled cars. I don't see anyone hitting a properly installed roll bar behind the seats in a Corvette. The collision would have to break the seat, and seat mounts, and/or twist the chassis to bring the bar in to toward the passenger. If you have proof of it happening, let me know. A full cage with halo and bars around and over the seats...absolutely.
Old Apr 3, 2018 | 10:22 PM
Ahrmike's Avatar
Ahrmike
Thanks for the input. I guess something like that doesnt exist yet?
I think since the behind the seat hoop/bar wouldn't be near your head you'd be okay without a helmet. A lot of convertibles run similar hoops behind the seats and as long as its in line with the top of the headrest of the seat and is bolted to the same platform as the seat, it wont go over it.
Here are some pics of flipped C5/6/7s:
http://gmauthority.com/blog/2011/07/...t-drive-drunk/
http://1.bp.blogspot.com/-SZQPnuEBaH...e-Crash-C7.jpg
https://www.zeroto60times.com/wp-con...e-rollover.jpg
https://cbsdenver.files.wordpress.co...0&h=360&crop=1
https://www.poughkeepsiejournal.com/...ice/431394002/
The A pillar is definitely a weak spot on the corvette and I dont think I've seen one picture online where the A pillar has withstood a rollover... but the B pillar/"halo"/hoop is also pretty weak. Its not triangulated - its just a large hoop over the entire car, and its made of spot welded stamped steel instead of an actual single piece bar...
Old Apr 4, 2018 | 12:56 AM
NSFW's Avatar
NSFW
With a 4-point bar behind the seats, just put some padding around the bar. That doesn't sound any more (or less) dangerous than hitting your head on the A-pillar, B-pillar, roof rails, passenger's head, etc.
Old Apr 4, 2018 | 11:23 AM
STANG KILLA SS's Avatar
STANG KILLA SS
theres these. but ive always assumed there mostly for show. i dont know.
http://rpmrollbar.com/c6-corvette-coupe/
Old Apr 4, 2018 | 02:28 PM
So Cal MotorsportZ's Avatar
So Cal MotorsportZ
ive got an SCCA RPM rollbar, super easy install and looks really nice. Like new 1200$ lightweight Chromolly and has all the extras. It’s in the vidoe of my car I just took last week. My car is in the shop now being fully gutted and turning it into a racecar so no need for the roll bar. 310-357-3366 call or tex me . Dustin
Old Apr 4, 2018 | 02:53 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
http://www.racespecialtydesigns.com/home.php
Old Apr 4, 2018 | 03:06 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Default Bolt in Roll bar for C5-C6
We make a 4 pt, bolt in roll bar that a lot of the Road racing and Mile competitors like to use. We build it without door bars and with a diagonal road racing style bar inside the main hoop. It is well behind the seats and you could not hit it unless you were not harnessed in.
We get $1,150 for it plus shipping.
Give me a call,
Steve@RSD
(707) 365-0117
Old Apr 4, 2018 | 05:12 PM
davidfarmer
Those are all aluminum cars, the b pillar in the c5 and base c6 is as strong as 1.75” tubing. It is thin wall but has a large cross section\moment
Old Apr 4, 2018 | 11:51 PM
Ahrmike's Avatar
Ahrmike
https://youtu.be/lVZqsTbUHcY
Thanks... the biggest problem for me is im located in Hawaii. Shipping will be a pain for an individual to ship to me... companies at least get some discount and might make it worth it
Old Apr 10, 2018 | 08:10 PM
Bill Dearborn's Avatar
Bill Dearborn
https://www.youtube.com/watch?v=WlsPNlGsTJU
Actually the hoop is in pretty good condition before he started dragging the car. It was similar to this hoop which held up well enough we could open the hatch after the driver flipped the car upside down at Watkins Glen.
I witnessed the incident as it was happening since the car was directly in front of my student's car. It was about 4 ft to 6 ft drop onto the roof of the car.
I have seen more roll over pictures with the top like this than smashed down. As I said when you look close at the video before the tow truck operator started dragging it the Halo looked like this one and then it started bending backwards as the car was dragged onto the roll back.
However, the A pillar is the big story. Whether or not the halo holds up a roll bar will do squat since the A pillar will collapse bringing the roof into the passenger space hitting the front of the head, bending the chin towards the chest with the occupant's body weight shoving the head further in toward the chest as the body stretches out as it hangs in the lap belt. I also know the instructor that happened to in that car. His back and neck had some compression injuries after that incident. The car was totally stock and they were using the stock 3 point belts.
Bill
Old Apr 10, 2018 | 10:10 PM
Ahrmike's Avatar
Ahrmike
Thanks for the insight. Do you think a roll bar is worth doing at all in that case? I would not want a roll cage simply because of the inconvenience of daily driving it. My head comes pretty close to the roof as I enter/exit already.
Old Apr 11, 2018 | 12:34 AM
exracer28's Avatar
exracer28
Default Hawaii roll bar
There are enough race shops on most of the islands that you can get a welded in bar for a lot less than shipping. Check with the SCCA group on your island or even the drag racers know of good shops. For a quality 4 point bar with a diagonal brace should be around $500 installed. Ask the local racers for advise.
To rollbars..
