Hub Stand Interest
#141
Former Vendor
The holes in the pivot plates are offset to the holes in the hub plate to allow for 0.250" height adjustments so there won't be a case when both line up but we will work on something to lock it in the vertical position. The Remove Before Flight tag is a great idea! Maybe we'll have some made that will say Remove Before Alignment!
-CSM Performance LLC
#142
Supporting Vendor
Received 2,316 Likes
Just finished my welding up my Ti "Supermod" tonight (bypass plus tip replacement with akropovic carbons and extensions for placement) so, should be able to pull the setup this week.
#143
Former Vendor
We're very excited to watch it! Also, if anyone would like to have their car on the hub stands posted on our website, please send us the pictures! If you dont want them featured on our website we'd still like to see them!
Hope everyone has a good 4th tomorrow!
#144
Former Vendor
To those who preordered, we sent out an email regarding the Toe Bars.
We had some business expenses increase over the last couple weeks and sadly we have to reflect that on our price. We believe our product is worth every penny and we stand behind it!
Also here are some photos of the finished product!
Updated Photos: 10-29-19
#145
I have laid a tape across the hub stands which allows me to mark the center line of the car both front and rear.
This allows a mark to be placed on the target at the center. From there you can shoot marks from the rear. The combination allows the front and rear toe to be set on each side as well as ensuring thrust angle is correct.
CSM Performance (07-06-2018)
#146
Former Vendor
one of the things which works real nice is to put a laser level on the toe bars and in against the lower hub stand supports, this allows you to shoot a mark on a target ahead of the car.
#147
Former Vendor
A few of announcements:
1.) For future orders, the Toe Bars will no longer be anodized black.
2.) We will not take orders from July 15th to August 22nd due to military obligations.
3.) We may have some standard 5 lug sets pre boxed to be shipping while I am away but we will not be able to work on custom plates during that time. This will be addressed on the website as well.
Thanks!
CSM Performance LLC
Thanks!
CSM Performance LLC
#148
Supporting Vendor
I'm just damn glad I was one of the few to get in while sh*t was priced hot...lol.
#149
Former Vendor
I expected the price on these to rise immediately, to be quite honest. You put out a pretty nice piece, and frankly I think 1k is still withing the territory of reason for a hobbyist. Typical set of lower end scales will cost you that...it's simply the price of entry. I'm ballz deep in my camper van build at the moment (mega roof rack with LED surround lighting, security camera system and solar), so looking to get to the Z06 next week. Have to mod my rolloffs to simple scale supports then get to it!
In all honesty we are still half of the price of other systems utilizing ball transfers and cheaper than the other styles out there.
#153
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I can’t quite set it at ride height due to BIG brakes but thinking it through, I don’t guess it matters.
#154
Former Vendor
Thanks!
Colton @ CSM Performance LLC
#155
Former Vendor
Taking order again! New orders will ship on August 27th !
Orders can be placed here:
FAQ can be found here:
#157
Former Vendor
We are offering a discount this weekend! You will receive $50 off a set of Precision Hub Stands with coupon code: "precision"
Description:
Easily align your vehicle with precision and accuracy with a complete set of Precision Hub Stands. Made with 6061-T6 Aluminum and Hardened Steel Hardware creating a stiff, rigid frame system. We utilize eight Ball Transfers and two Hardened Steel Pivot Bolts to create an extremely low friction surface for caster, camber, and toe movements which eliminates virtually all resistance that a tire would present when aligning a vehicle. This means you no longer have to roll your vehicle back and forth with every alignment setting change! Each Precision Hub Stand is capable of supporting up to 1000 lbs (4000lb vehicle with 50/50 weight distribution) and adjustable in 0.250” increments from 11.4375” (~11.5″) to center line to *15.4375” (~15.5″) to center line which will accurately represent the tire height of almost any sports or race car. We have added a toe bar to each hub stand with three different positions for measuring wheel to wheel or from string to wheel. We bolt on rare earth magnets to the end of each toe bar to assist in holding the tape measure ends. Finally, we mount threaded feet to hold the Hub Stands in place when needed. We offer three main hub mounting plates. They can be found under the “Wheel Bolt Pattern” option above. If you would like to utilize these as wheel dollies on a smooth shop floor and allow easy access to all suspension components feel free! If you need a different bolt pattern, height, weight requirement, or anything you would like, give us a call and we can make it happen!
A set of Precision Hub Stands can be purchased here:
https://csmperformance.com/
Description:
