Carbon fiber wing
jloZ06 (04-11-2018)
Supporting Vendor
Received 2,316 Likes
What method did you use. Did you make a buck and seam the mold in two halfs or what? Just curious. What weight do you have there, do you know? Internal full width spar or? Do show, do show!
I'm actually going to modify the inner parts a bit for ease of manufacture but pretty much done.
I've been working on this since about Nov .
The skins are 4layers 5.7 1 layer 20oz uni directional and the spars are 45°x45° biaxial 12oz
the fish are multi layers of 5.7 and biaxial .
I haven't stood on it yet but I'd bet I could park a truck on it .
yes and that # just keeps climbing. The hardware to mount my uprights alone was $40!!
without actually adding everything right yet I'm guessing just a wing with endplates will be around 2k .Hopefully my Local waterjet guy doesn't charge too much to cut the uprights .
Supporting Vendor
Yeah, figured as much. Tough to make something legit much more affordable than that, especially in low production. I have found a pretty cheap 72" fiberglass piece that some people I know have run with great results. It's no mega quality piece, but for a budget track beast, it does work....550.00.
It's not a product I'd lead off with personally. You make other carbon parts?
Supporting Vendor
Nice...I've done a lot of composite stuff over the past 15 or so years. I want to create some new products and do vacuum infusion/low production. I never got big into mold making though...did a lot of overlays, flat panels, and very crude molds. I want to step my game up though in the short future and offer some things I have in mind.
Just was curious what you're up to...lol. 2k is a pretty good price overall though, looks like the quality will be there.
taking your time with the mold is the tough part. The infusion is the easy part
Supporting Vendor
Yeah, I've attempted a few molds in the past, but I've had too much movement and I need something low production worthy. Can you give some advice on what is best for the mold? I have tried (and failed) with quite a bit...lol. I'm thinking polyester resin and 1 1/2oz chopped strand mat, but how many layers to be good?
I gave up on poly it stinks and it sucks to work with and you have to be so precise with the hardener or it will kick on you too soon. I switched over to a epoxy surface coat and epoxy molds. You can use a hardener that gives you 15 minutes or one that gives you 60 minutes depending on the part you're making then once it tacks lay epoxy and fiberglass I usually do two or three layers of 6 oz to prevent print through and then four or five layers of 10 ounce at least that gives a pretty stout mold depending on the shape and size obviously
premium resin tech has great stuff and he stands behind his product . I made a mistake on one of my molds and asked him about it he asked for a sample and I sent him a sample of the mold off of a corner and in the meantime he sent me over $500 of materials just to remake the mold before he even figured out what was wrong.
He's out of Michigan too so no overseas crap .
Supporting Vendor
Oh wow...that's pretty solid. I've been using west system stuff for epoxy. I just go too thin on the molds. I'm always sweatin that resin use...lol. Making a solid mold is pricey as f***
West system is your 1st problem. That stuff is an old formula of epoxy and very expensive. Look at US Composites for more affordable epoxies I think a gallon goes for around 75 bucks I won't typically pay more than $120 for a gallon it's about the same for surface codes too .
I use soller composites for my Fabrics. Pretty reasonable .I love their 820 infusion epoxy too .Thin, flows well, long pot life and "UV stable" whatever that actually means .
Supporting Vendor
Man, thanks for the tips. I'm hoping to jump in on a few project ideas this summer and really am going to make a more concerted and serious go at it. It's hard to find experienced advise I've found, and the internet is littered with trash info mixed in with the good.
I clearly need to re-assess.
What Naca profile did you use?
a slight variation of the MSHD not sure if it's a NACA but FSAE teams used it and it has quite a bit of cfd already done on it it has a trailing edge stall so it doesn't fall off a cliff so to speak.
I'm also going to make a 12" chord with much less camber and test back to back to see some real world differences.
