Swaybars for C7Z51 - Hotchkis or LG?
Old 04-23-2018, 10:47 PM
RapidC84B
RapidC84B's Avatar
Received 13,169 Likes on 5,991 Posts
Default Swaybars for C7Z51 - Hotchkis or LG?
Pfadt/AFE are orange so they're out
Hotchkis are 35% stiffer and have an adjustable rear bar; fixed front.
LG is adjustable front, fixed rear and say they're 40% stiffer.
My experience is a fixed rear bar can be an issue. If the car is tail happy you have no options.
Anyone use either?
EDIT - Pfadt bars are here... they're big, similar to the T1 bars on my C5 racecar.
Old 04-24-2018, 03:21 PM
snow
Support Corvetteforum!
snow's Avatar
St. Jude Donor '10, '17-'18-'19
I have the LG and love them... car stays super flat.
Old 04-24-2018, 07:02 PM
RapidC84B
RapidC84B's Avatar
How do you use the car and what skill level would you rate yourself? Any issues with excess or snappy oversteer st the limit?
Old 04-25-2018, 09:51 PM
RapidC84B
RapidC84B's Avatar
Ended up with a blem set of Pfadts... hate the orange, but after a lot of research they're the only mfg who makes a set with both the front and rear bars adjustable.
Old 04-27-2018, 03:13 PM
Chets LS3
Chets LS3's Avatar
LG all the way. I had hotchkis and moved to LG. I was also on slicks an running TT with other mods.
Old 04-28-2018, 02:00 PM
RapidC84B
RapidC84B's Avatar
lg rear bar is fixed which is silly for a track car.
Old 04-28-2018, 03:38 PM
Chets LS3
Chets LS3's Avatar
I agree that’s a negative. Luckily I was able to make it work. The adjustability in the hotxhkis all around was just not enough bar. I also never had issues with oversteer that I felt was caused by suspension.
Old 04-28-2018, 07:24 PM
Racingswh
Racingswh's Avatar
Received 1,074 Likes on 644 Posts
What would be the issue with getting the LG front adjustable and Hotchkis rear adjustable? Softer and adjustability would be a plus for the rear bar and wouldn't deter me.
My C6Z happens to have a set of Heavy Rate adjustable Pfadt's still going strong.
Old 04-28-2018, 07:45 PM
Chets LS3
Chets LS3's Avatar
I tried that. Worked a little better for autox but in track form the non adj LG felt better set up and overall flatter. I was running a z51 with msrc, camber plates and slicks.
Old 05-04-2018, 09:13 PM
RapidC84B
RapidC84B's Avatar
Pfadt bars showed up. Installing this weekend. VIR for Hyperfest weekend after next.
To Swaybars for C7Z51 - Hotchkis or LG?
Quick Reply: Swaybars for C7Z51 - Hotchkis or LG?
