Slotted vs Blank Rotors: C5 Z06 Track Use
So another brake question....
Been cracking my NAPA/Autozone/Etc rotors much too quickly for my liking, even with extra cooldown periods.
Considering a slight upgrade to better rotors, but am torn between the two options below (same price and appear to almost be identical). Only Difference appears to be slotted vs blank face. Not considering two-piece at this point.
Does anyone have experience with slotted vs blank rotors at the track? (not talking drilled, only slotted).
KNS Blanks:
https://knsbrakes.com/c/car-series/1...-+Single+Rotor
vs
DBA T2 Slotted
Thanks for the help!
KNS Blanks:
vs
DBA T2 Slotted
KNS Blanks:
vs
DBA T2 Slotted
KNS Blanks:
vs
DBA T2 Slotted
Blank ones are cheaper. In many SCCA classes they have to run blank rotors. Slotted rotators may help release heat better, but I don't if it makes that much difference given the extra expense. I have used blank ones for racing on a BMW, VW and ZO6.
Spaggs
Spaggs
Spaggs
Spaggs
Proper cooling ducts would likely help a fair amount more than different rotors. I have the Quantum kit and have run both the KNS rotors you reference. I don't see a material difference in their wear rates. Now that I think about it, I have cracked more rear rotors than fronts since the Quantum install.
'04Z06 (05-24-2018)
I now have the AP racing two piece rotors on my C5Z....I don't run any duct work yet as I haven't had any braking issues. But most of my tracks are under 130 mph when coming into corners. But two piece rotors would probably handle the expansion and contraction better if the ducted air was hitting them. I know you're supposed to duct the air in towards the hub so it goes through the vanes and cools both sides of the rotor face....not always as easy to accomplish as it sounds.
I cracked 6 sets of stock rotors one season. Switched to the C6 Z51 rotors in blank form.
They are 13.4inF/13inR vs 12.6/12 for the stock rotors. LOT's more mass
Still fits under the stock 17/18in wheels too.
Haven't cracked one since.
I assume you switched to C6 brakes rotors AND calipers or just rotors and an adapter braket to move the C5 calipers?
Received 8,926 Likes
Not sure what the price on the NAPA rotors is nowadays but you should consider the overall cost as well as how long other rotors may last. Running at the Glen I used to crack the NAPAs after two but sometimes three track days. It didn't matter much whether they were front or rear. When I considered all available options including pricing it was lower cost to run the NAPAs so I just carried a set of spares in the rear of the Tahoe. Of course when I started purchasing them in 2003 they were $25 each and had gone up to $50 each by the time I sold the C5Z in 2009. With a battery powered impact wrench to handle the caliper bolts I was able to change a rotor in a short period of time with the car sitting on a jack stand in the paddock. The biggest hassle was getting the tools and parts out of the Tahoe.
Bill
Bill
I used stock c5 front calipers and the c6 rears due to the smaller piston.
Probably the biggest factor to rotor cracking is actually the TCS. If you run with it on, it kills brakes.
I can run a 1:40 at barber in the dry on trofeo R's no brake fade but in the rain on all seasons I faded the brakes running 10 seconds slower.
What was the difference?
TCS was in competition mode
https://youtu.be/ZXKOLYWBCcY
I used the centric high carbon blanks.
Everyone, thanks for the advice! Looks like the advice is summed up as:
- (Cheapish) Blanks are a good value, just treat them as consumables. Higher quality ones may last a bit longer
- Cooling will help, but needs to be installed properly to cool both sides of the rotor
- PTM: if not disabled, can have a large impact on brake wear
I have run:
el'cheapo wagners - one cracked 2nd session
lots of OEM c5 - get about four track days
lots of OEM c6 - get about four track days
KNS Blanks - currently on car
I typically change when they have lots of fine cracks, just prior to cracking through. I think the KNS may be lasting marginally longer.
I have additional cooling ducts, do a real cool-down last lap (usually pisses off everyone behind me), coast the pits before parking, and roll the car a few feet after being parked for a few min (moves that hot section of rotor between the pads). I don't think any of it really helps.
A lot probably depends on the pads. I use PFC01 up front. I don't remember their operating temp but at my last track day a corner worker (end of a straight) said my front rotors were glowing red.
I recently change the rears to ST43's and those rotors (OEM C5 rears) look great.
I've seen club racers run with rotors that has thousands of those micro-cracks on the surface. When I ask about it, the response is usually "meh. Because race car."
mountainbiker2 (05-31-2018)
I can vouch for Centric blanks off of Tire Rack. I've run them + Carbotech XP8s / XP10s for 2 seasons (in beginner group, mind you, but I am not easy on the slow-pedal as some others) and had no issues when coupled with RBF600, Speigler SSBLs, Katech front splitter brake duct inlets + LG spindle ducts. I would like to think my brake game is strong.
