Sparco Competition Seats
Old 07-24-2018, 08:09 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Sparco Competition Seats
FREE SHIPPING LOWER US
http://www.xplosiveperformance.com/R...ats_c_840.html
Old 07-27-2018, 01:58 PM
Former Vendor
St. Jude Donor '13
CHECK OUT THE NEW
Sparco-QRT-R-US-Fiberglass-Racing-Seat
http://www.xplosiveperformance.com/S...at_p_4204.html
The weight of a carbon fiber seat with the price of a fiberglass seat.
The latest racing seat from Sparco showcases their newest, patented, QRT Ultra-Light Technology. The Sparco QRT-R offers an industry unmatched strength-to-weight ratio for fiberglass composite seats. With an average weight savings of 7lbs per shell, the QRT-R approaches the weight of a carbon fiber seat while keeping the price of a fiberglass seat. Better yet, Sparco gifted the QRT-R with a unique CAD design that offers an excellent fit for most drivers, while keeping exterior dimensions that can easily fit into smaller cockpits. With a shell weight of just under 10 lbs, the US-specific QRT-R is FIA approved and features taller shoulder guide openings to fit more drivers, and mounting that is compatible with all current Sparco brackets.
Technical Information
Rating: FIA 8855-1999
Shell: Fiberglass
Weight (lbs): 9.9 lbs. (Shell only)
Mounting: Side
Manufacturer: 008005RNR
• Light-weight fiberglass shell using QRT Technology (7-10lbs weight savings)
• Lower seating position that can fit taller/larger drivers
• Compact outer dimensions for easier installation
• Harness guides that can accommodate a wide range of drivers
• Hans Compatible
Sparco QRT-R Seat Sizing Chart
A: Internal width at torso bolsters
B: External width at torso bolsters
C: Internal Width at center cushion
D: External width across thigh bolsters
E: External width at shoulders
F: Base Width
G: Base length (Front-to-Back)
H: Mounting Hole Span (Side-Mounting seats only)
I: Projection of Seatback
L: Height from base to shoulder wings
M: Height (Top-to-Bottom)
Note: All measurements are in millimeters. Measurements are based on the seat shell, and do not take into account padding thickness.
Quick Reply: Sparco Competition Seats
