Scca Gt2 Hp ? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Scca Gt2 Hp ?
Old 07-30-2018, 09:28 PM
Hi Volts Z06
CF Senior Member
Hi Volts Z06's Avatar
Originally Posted by mp4659 View Post
Gt2 is more similar to st2 then t-1 is to st2. Gt2 is less aero but more hp then st2, so a little less wing/splitter and then swap tunes and I really think car could be competitive in both classes
Just seems like you are going to have to shed HP for NASA and then your missing the aero with the SCCA trim. (But hey.... your too fast now anyway so go for it).
Hi Volts Z06 is offline
Old 07-30-2018, 09:43 PM
clubracer23
CF Member
Originally Posted by RX7 KLR View Post
The dominate car has been a C6 at 3130lbs with a 75mm plate (these are 2017 specs, pretty sure it only had to weigh 3030lbs in 2016).
My guess is he’s using a “built” L76 with a 75mm flat plate restrictor (3000 lbs.) with ported heads (+30 lbs.) and slick tires (+100lbs.) to get to 3130 lbs. He has a lot more going on there than just the “right”’engine for the class.
clubracer23 is offline
Old 07-31-2018, 10:57 AM
bosco022
CF Senior Member
bosco022's Avatar
Randy Kinsland has won a slew of very competitive SE Div SCCA Majors and Trans Am 3 races as well in his ex Bob Mayer/Scotty B White Corvette. He has been very successful with both LS6 and LS2.
bosco022 is offline
Old 07-31-2018, 02:13 PM
HULLY
CF Member
Support Corvetteforum!
HULLY's Avatar
im not really sure how that acp wing is gt2 legal but im not complaining....from what i could tell max wing length is 68'' and 10.75 cord, with a footnote allowing the apr gtc500.
This car is for sure legal. It runs under the GT2/ST rules which are in Appendix K. 72" width 12" cord
HULLY is offline
Old 08-02-2018, 02:05 PM
DJFIN
CF Member
The extra 100 pounds is for the sequential transmission.
DJFIN is offline
The Following User Says Thank You to DJFIN For This Useful Post:
clubracer23 (08-03-2018)
Old 08-02-2018, 02:13 PM
DJFIN
CF Member
A built ls7 could do 500-550 through a 65mm sir. My ls7 (rip) was stock other then headers and heads done (stock cam, intake, throttle body etc) made 470whp. We detuned it to 400whp for Nasa st2. I would like to build an all forged ls3 this go round.
The rule is 3200 pounds for a built LS7 with a 65mm flat plate restrictor, not a 65mm SIR. Notice what AA is running!
DJFIN is offline
Old 08-02-2018, 06:44 PM
mp4659
CF Senior Member
65mm flat plate restrictor an ls7 can still make relatively big power. I cant afford a sequential so I am leaning towards an ls7 build salvaging the top end of my old motor.
mp4659 is offline
Old 08-07-2018, 02:46 PM
DJFIN
CF Member
I'm in no way telling you what to do, just clarifying the rules. The extra 250 pounds is about 8% more weight, so you will have to make about 40 more hp then a built LS2 so around 515 hp to be even. Don't know if you can achieve that thru a 65 mm flat plate restrictor or not. I can't afford the $30K sequential trans either so I have a Rockland Gear close ratio "Transzilla" in my car. Also trying to point out that an LS3 isn't a good option per current rules. I have spoken to SCCA about this as well. Seams to me they are favoring the LS2 which GM has obsoleted, very odd.
Good luck either way.
Robert Finlayson
DJFIN is offline
Olitho (08-07-2018)
Old 08-07-2018, 03:03 PM
mp4659
CF Senior Member
Robert Finlayson
had a long talk with my engine builder and he agrees with you 100% , I was wrong! Looks like I’ll be building an ls2
mp4659 is offline
Old 08-07-2018, 03:29 PM
clubracer23
CF Member
Why no love for the L76 that is the same weight and restrictor as the LS2? It's a LS2 block with LS3 heads and intake.
The rules are very convoluted but with the way they are written I like either the "built" LS6 option (unrestricted) or "built" L76 with 75mm flat plate restrictor.
Old 08-07-2018, 04:36 PM
HULLY
CF Member
HULLY's Avatar
If you think you will ever race in Trans Am3 the L76 is not a listed engine. You could probably get a waiver but im sure it would cost a weight or restrictor penalty.
HULLY is offline
The Following User Says Thank You to HULLY For This Useful Post:
clubracer23 (08-07-2018)
Old 08-07-2018, 05:14 PM
clubracer23
CF Member
Thanks! I know nothing about and have no plans to race Trans Am3 but now I understand why no-one is talking about the L76 engine but me!
Old 08-08-2018, 02:26 PM
  #33
Captain Buddha
CF Senior Member
Captain Buddha's Avatar
Building your car with an eye to be able to run in TA3 would be a prudent move - more racing opportunities!
Captain Buddha is offline
Old 09-12-2018, 10:10 PM
  #34
clubracer23
CF Member
Is there an un-published alternate spec out there for the SCCA GT2 engine/car like World Challenge or something? I swear I saw a GT2 C6 Corvette earlier this year with a FAST intake manifold on it (@3130 lbs.) and I can’t find that allowance anywhere in the SCCA GCR.
Old 09-13-2018, 03:04 PM
  #35
DJFIN
CF Member
I have seen that car as well. It is black and has FAST on the side. I don't know if he has a FAST intake on the car or not. If he does, it isn't legal for SCCA GT2.
DJFIN is offline
Old 09-13-2018, 04:20 PM
  #36
fatbillybob
CF Senior Member
fatbillybob's Avatar
Often a car is classed and runs fine even if illegal if it is not protested or on the podium. The most likely challenge would come at a serious Runoffs even where the scruts pick from a menu of things they want to check the cars in your class for.
fatbillybob is offline
Quick Reply: Scca Gt2 Hp ?
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
