Alternator died from overheating.
The Ac Delco alternator (19152464) (from a 1992 Camaro CS130 casing) unit finally failed due to overheating. I am looking for replacement parts that will do better.
This unit is from a GM Serpentine conversion for my C3 1978 corvette. What brands are you track guys using after the factory units fail. ?
I would like to keep the same connections if possible, but it must mount the same and I can adapt the electrical connections.
