Wilwood Aero6 Calipers and C6Z Rotors?
Old 08-13-2018, 05:03 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
Default Wilwood Aero6 Calipers and C6Z Rotors?
I may have missed if this was asked in the past.
I purchased the Aero6 spec corvette setup with fixed 14" rotors and aluminum hats for my C5. Can I run the stock 14" C6Z rotors with that setup? Do they have the same offset as Wilwood?
I'm thinking of carrying these as spares as it would be quicker to change out at the track versus bolting / wiring the hats. But only if I don't need to re-shim the calipers to be centered on the different rotors.
Do the stock rotors give up a lot of life compared to the non-floating Wilwoods?
Rob
Rx7Rob is offline
Old 08-13-2018, 05:34 PM
Joshboody
CF Senior Member
AFAIK not if you have the 20mm pad kit. I purchased the 17mm kit so I could run c6z rotors mainly for the easy of spares.
Joshboody is offline
Old 08-13-2018, 07:19 PM
MX621
CF Senior Member
MX621's Avatar
how do you like the kit? Itís deff on my radar. How
often you track it? Deff seems like a lot of bang for the buck. I would also be interested in how good the Wilwood rotors are vs say a 50$ cryo centric c6z rotor
MX621 is offline
Old 08-13-2018, 08:12 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
I think the willwood and C6Z rotors are the same width, so maybe there is a difference in the offset.
MX6, the kit just got delivered. I'll finish off this year with my current setup and install the brakes this winter (along with square tires / rims, changing the front ride height and realignment). Just got a Sparco seat as well. I'm going to make my own mount, but that will go in before my next track event.
Rx7Rob is offline
Old 08-13-2018, 09:16 PM
hungryhippo
CF Senior Member
hungryhippo's Avatar
It depends which kit you have. Wilwood makes separate kits for use with c6 z06 rotors or wilwood rotors. They are different offsets.
hungryhippo is offline
Old 08-14-2018, 04:41 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
This is the hat that comes with the kit: 170-8132. Edit, geesh, I keep going back and forth on the hat. I'll look at whats actually in the box tonight but I think its this one: 170-8919
Any idea of the stock rotor offset is? Probably easier for me to just find a trashed stock rotor locally and just try it.
Rx7Rob is offline
Old 08-14-2018, 06:21 PM
Joshboody
CF Senior Member
WW also has c6z 2pc so you can compare hat dimensions on their site.
Old 08-14-2018, 06:29 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
Good idea!!
Rx7Rob is offline
Old 08-14-2018, 07:47 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
The WW C6Z 2-piece rotors have a hat offset of .23". The hats in my kit have .29" offset. Good suggestion Josh. Guess I'll order another set of rings and keep the safety wire / pliers in with my track tools!
Rx7Rob is offline
Old 08-14-2018, 07:53 PM
MX621
CF Senior Member
MX621's Avatar
Iím assuming the diff offset is to accommodate the 20mm padded race calipers. Vs the 17mm calipers that accept the stock c6z rotors? This kit has my attention, for obvious reasons I favor the race kit, but your stuck with fewer pad selection and the specific rotor. My Z is still a street car as well so maybe the 17mm caliper would work best?
MX621 is offline
Old 08-14-2018, 08:44 PM
Todd TCE
Supporting Vendor
Todd TCE's Avatar
Here's the poop.
1. The Aero6 CALIPER kit fits the stock rotor.
2. The Aero6 14.25" kit with 2pc hats and rotors and 17mm pads fit the supplied rotor.
3. The Aero6 14" Race kits with 2pc hats and rotors with 20mm pads fit the supplied rotor.
NONE of these will interchange with the other. We can go into great detail about the exact whys and hows but trust me: they don't.
*You can however purchase an alternate brand 2pc hat and rotor of EXACT OE SPEC in place of the one piece stock rotor and the CALIPER KIT will work with that.
*You can also purchase a Wilwood brand 2pc OE SPEC replacement rotor kit to use with the CALIPER KIT (which would be foolishly more expensive then just buying the complete kit) but you cannot use THAT 2pc with the complete kit in option 2.
NONE of the parts interchange with the RACE kit: hat, rotor, pad, caliper, bracket....
__________________
TCE
Your one stop...for Wilwood Brakes!
480.967.7901
* CUSTOM * Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * Crown Vic * Super Duty * Flex/SHO * Mustang * WRX * ...and more!
Todd TCE is offline
Old 08-15-2018, 12:46 PM
MX621
CF Senior Member
MX621's Avatar
Originally Posted by Todd TCE View Post
Here's the poop.
thanks for clearing that up. So letís say I wanted to
go with the race kit that uses the 20mm pads. My car is still a street car as well so could i use the polymatrix E pads on the same rotor on the street, then the bp40 pad on track? I saw in the Wilwood literature it says ď ok for streetĒ with the E compound. Are the diff Wilwood compounds compatible on same rotor?
MX621 is offline
Todd TCE (08-15-2018)
Old 08-15-2018, 02:11 PM
Todd TCE
Supporting Vendor
Todd TCE's Avatar
Yes you could move from E to the H or 40s with minimal bedding between pad use. *I'd personally say that while "streetable" you'd likely find the E pads quite loud and abrasive for normal day use. The other option would be 17mm pads but use them with a pad wear plate to take up the lack of friction material ideally.
No reason you cannot use the 'race'; kit for the street but beware the hats and rotors may prove a bit loud cold due to the tee lug drives used for expansion and that they will have a serious impact on wheel choice. OE wheels may require a spacer so see the wheel fitment page to be certain.
__________________
TCE
480.967.7901
Todd TCE is offline
Old 08-15-2018, 04:43 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
Todd, thanks for the rotor / caliper interchange info.
MX, I went with the 17mm BP10 street pads. I like to make stuff so I'll knock out a bunch of pad spacers in various thicknesses.
The public release for the race kit said it comes with BP40. WW website for the kit says BP40 in the description and BP30 in the kit components info. It came with BP30 in the box.
Rx7Rob is offline
Old 08-19-2018, 11:24 AM
Brad Williams
Junior Member
Will the race calipers(for 20mm pads) fit under 18x10.5 speedline's without a spacer?
Brad Williams is offline
Old 08-19-2018, 07:48 PM
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
https://www.corvetteforum.com/forums...post1596879734
Rx7Rob is offline
Old 08-22-2018, 07:46 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 3,753 Likes on 2,479 Posts
If you have the Aero6 Calipers that replace the stock calipers (Wilwood Part Number 140-12629) that use the stock rotor you can replace that rotor with the following rotor from Wilwood:
https://www.wilwood.com/BrakeKits/Br...tte&option=Z06 . 140-12496 is a drilled slotted rotor two piece rotor that will work with the Wilwood stock replacement calipers.
Before the Aero6 became available I had the W6A version of the caliper which replaced the stock caliper and worked with the stock rotor. I then replaced the stock rotors with this part number to get a full Wilwood 14 inch rotor and caliper setup. I ran the Wilwood rotors and had a couple of used stock rotors as spares if I happened to crack a Wilwood Rotor. I never did crack one. I had 13 track days on the first set of rings and decided to put some new ones on even though they weren't close to cracking. 160-12391 and 160-12392 are the replacement rotor rings for this set.
I used H pads on the track and Q pads on the street.
Todd provided all of the parts for me at great prices.
Bill
Bill Dearborn is offline
The following 2 users liked this post by Bill Dearborn:
Flying24 (09-05-2018), Todd TCE (08-23-2018)
Quick Reply: Wilwood Aero6 Calipers and C6Z Rotors?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
