Extended seat threads for harness
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Hi guys, has anyone made, or found a more cost effective way to extend the rear seat threads to install a harness? I found bolt adapters with extended threads from corvette mods but $25 per unit plus shipping in Canadian dollars is a bit excessive...any other ideas?
thanks
thanks
thanks
thanks
I just hammer out the old bolts, use longer bolts with fender washers from the bottom. They have a small weld you can cut, or just hammer them out. Install bolts from the bottom, or they will drag the ground when loading etc.
nothing wrong with spending $50 on those if you prefer.....I've used them with Hardbar kits, but when I'm making my own mounts I prefer using locally sourced graded hardware for about $3
As others have noted, just pop out the OEM stud and replace with a proper bolt from below.
Here's a good thread on the subject with some pics. I found it helpful, anyway, when installing my Sharkbar down tubes a few years back. As I recall I ended up giving mine a love tap from below with the air chisel and they surrendered pretty quickly.
https://www.corvetteforum.com/forums...d-removal.html
In my case I decided to just reuse the factory nuts so I went with a metric flange head bolt instead of the 3/8" bolt noted in the link. Stock thread is M10x1.50 and you'll want to spec the bolt's grip length for your particular stack-up thickness. Be sure to use minimum Prop Class 10.9 if going metric or Grade 8 if standard and use hardened washers.
I used a bit of my grassroots brain and then pulled a page from the Porsche handbook and installed these onto the rear bolts with just enough room to tighten the bolts for full thread engagement. They were a PITA to get on, bolted down, and get the harnesses clipped in, but I am very confident that they are secure. NOTE: These only work with the clip in style harnesses. I'm running 6pt clip-in Schroth harnesses.
Purchased here:
https://www.automotion.com/safety-ha...r-porsche.html
I will snap some pics and post them soon of how they are mounted / secured.
Purchased here:
In preparation for this job I ended up buying hardened M12 boots instead of M10. I also bought a 3/8 heavy steel bar for reinforcement from underneath. I assume that I will have to drill the entry hole a little bigger to accommodate the M12 bolt...has anyone gone this route?
Per the thread in Fulton 1's post, I recommend using a jack and deep socket to support the underside of the seat mount bracket (on the exterior of the car) to avoid tearing up the stamping. The welds can be pretty tough and without support it'll bend & tear the stamped metal bracket. I used a cold chisel but an air chisel would be good for breaking the welds once the stud head begins to separate from the stamping.
STALION (08-27-2018)
Received 8,918 Likes
Bill
Purchased here:
Purchased here:
