c6z wheel hubs
c6z wheel hubs
Can anyone recommend a good Wheel Hub for track duty? I have replaced 3 AC delco hubs this summer , Was in a pinch went to Auto Zone and their cheap hub did not last 10 minutes. Very frustrating
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
SKF is the way to go. Even with heavy track use and heat from carbon ceramic brakes, I usually get at least two years out or fronts and 3+ years out of the rears
St Jude Drive every year
Max G’s
Supporting Vendor
St. Jude Donor '11
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
What are the factory hub equivalent, AC Delco or SKF? I have 100,000 miles and 3 years worth of track days on the original hubs. I don’t have an unlimited budget and do this just for fun. Just curious if my factory hubs have lasted this long I’d be OK with a direct replacement if it’s half the cost.
Supporting Vendor
St. Jude Donor '11
So the AC Delco would be the factory equivalent? I generally try to conserve my car on track. I drive there and back so I’m not trying to get 10/10’s out of it. I’m going to assume that for me, the AC Delco will probably last longer than I will be doing track days.
I'm switching over to SKF, and found Joe at Phoenix to be about the best price. He pointed out that the fronts and rears are identical except the rears have a splined hole so I'm only going to buy rears so a spare works anywhere.
Supporting Vendor
St. Jude Donor '11
That is correct...personally the down time and risk of down time IMO is worth getting the better hub. If your at the track and your hub fails at best you lost money spent for the weekend.. at worst it lost up and you hit a wall and suffer some serious damage to your car.
